PROJECT LOG Lian Li 343B Mod
Nidor
Coast of Norway
Hello there OCforums, I used this forum way back when I was getting into watercooling and I learned a lot from you guys! Since then I have built and done and redone my system a lot, I went from a Microcool Banchetto Testbench to a Lian Li 343B. Finally last year I got tired of the 343B and decided to redo the system, I started scouring for cases and I found a lot of interesting choices, but I couldn't really justify some of the price tags when I had a perfectly good case at hand.
I then decided that I would go the path that some of you folks have shown me on so many amazing builds on this and other forums! I decided to gut the thing and give modding a go!
The result is not entirely finished yet, so this is kind of a Project Log starting about 80% done.
I've seen a lot of interesting 343B builds out there and the ones I found most enticing were the horizontal motherboard ones, so I decided to go that route.
I drilled out every rivet in the case except the ones keeping the cube frame together and then started working out where to go from there. I then cut out the entire back panel of the case and had a blank backplate made that I could work with. I had a Mountain Mods modular motherboard tray lying around that I used to test systems on and I decided why not use this as my actual motherboard tray! I did some very basic modelling in Google SketchUp and figured out that the best way to mount said motherboard would be about 15cm off the floor of the case. So I got a couple of 15cm square rods to support the back of the tray and got the tray attached to the backplate.
Now I had a very basic case setup. The idea I had was to stick the PSU, a pump and HDD rack under the motherboard tray. I've made a couple of side panels to cover up what's under the motherboard tray, I am not fully satisfied with how they look with the rest of the case yet, but I will think of a solution.
Now enough of my blabbering :blah:
Picture time!
What I started out with as described above
This is what I managed to work together in my first test fit :)
The dog is very important, respect the dog.
This is how it looked while on my 2nd Mountain Mods board that I use for out of case rigs, as I regularly game online with friends I kind of had to have it up and running while I put whatever spare time I had into the case :)
When I felt ready enough I got the case parts powdercoated by a friend!
This is what my 2nd test fit looks like, while scouring across the interwebz and forums I came across the Primochill Rigid Acrylic tubing and fell in love. I watched videos about it found forum threads and scoured the web for pretty much anything I could find about it!
I ordered the primochill tubing and fittings and then I got some monsoon bending kits to work with, and well you can see the results!
Here the wire for the temp readers had dislodged so it had no power :/ I also intend to paint the ODD white, don't worry it won't be an eyesore!
This is how my gaming setup looks at the moment :)
Now I'd like to state that this is my first go at an actual project log so please be nice :)
Rest of the pictures can be found on my imgur: nidorz.imgur.com
To be quite honest I'm not the best photographer and the only times I've had time to take pictures it's been quite dark :/
Thanks a lot!
