I'm a Soldier returning from a tour in Iraq and I decided my AMD FX-55 PC needed an overhaul. This is my 1st and a half attempt at a WC system, the first attempt being a Zalman kit (I know). So, I've been painstakingly re-acquainting myself with the changes since I last built a computer. This time around I want to do it right, from the start. I've begun ordering the various PC components, but since I am not yet back in the States I can't give you the ambient/idle/load temps for obvious reasons. I am going to hold off on buying the WC components until I get the blessing of my more experienced comrades. Budget isn't a big issue, as I said I want it done right, but I'm not looking for extreme performance either.
Here is what I am looking for in my LCS:
-Achieve an acceptable level of overclock at a low noise level, however Performance still trumps Noise.
-Cool CPU/GPUs, if feasible everything else.
-Prefer all internal WC, as such I don't think the case will allow dual-loop (space-permitting I would like to fit it in).
The components of my PC:
-Corsair 800D Full Tower Case
-Core i7 920
-ASUS P6T Deluxe V2 x58 mobo
-Corsair Dominator DDR3 PC3-12800 1600MHz 6GB TR3X6G1600C8D
-Patriot Torqx 128GB SSD
-2x EVGA GTX 285 1GB (01G-P3-1180-AR) in SLI
-CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready
The case has space for a top-mounted 120x3 rad and comes with 3x140mm built-in fans (space for 7 fans total).
Currently what I am looking at component wise:
Reservoir: Syscooling ART11 Transparent Long Reservoir 275mm, 50mm diameter 3/8" ID fittings
Pump: DD / Laing DDC 3.25 -12V 18 Watt Version
CPU Block: Koolance CPU-350 (although I'm concerned with its flow restriction if it will hamper the GPUs on a single-loop)
GPU Block: 2x DD-GTX285 Version 2
Radiator: #1: XSPC RX360 w/ 3x Yate Loon Mediums #2: Black Ice® GTX Gen Two Xtreme 140 w/ case stock fan
Liquid: Distilled water + PHN Nuke
Tubing:Tygon 3603 tubing 3/8" ID
Clamps: I would like to use compression fittings throughout
My plan for the loop is Res>Pump>Rad#2>CPU>GPUs>Rad#1>Res (This seems to be the most practical, without having tubes going all over the case, however I'm not sure it is the most efficient for cooling)
Would someone with more experience look this over, shoot holes in it and add their two cents?
-Core i7 920
