- Apr 27, 2002
[size=+3]New samples[/size]
http://mywebpages.comcast.net/bballmadness/bassiloveyou.mp3
http://mywebpages.comcast.net/bballmadness/bassotronicswithbassmekanik.mp3
good bass with a mix of clean highs. useful for balancing the subwoofer with the tweeter in a system
http://mywebpages.comcast.net/bballmadness/thx_-_jurassic_lunch.mp3
warning comes with this one. do NOT play at high volumes. you WILL bottom out your subwoofer. this file has content at 15hz.
http://mywebpages.comcast.net/bballmadness/phase.mp3
http://mywebpages.comcast.net/bballmadness/DrumSolo.mp3
http://mywebpages.comcast.net/bballmadness/Big8DrumLine.mp3
http://mywebpages.comcast.net/bballmadness/DolbyBassTest.mp3
Frequency Analysis: Sigview (program i use)
http://www.sigview.com/download.htm
Another frequency analysis program : TrueAudio (RyanT prefers this program)
http://www.trueaudio.com/downloads/TrueRTA_se.exe
Tone Generator
http://mywebpages.comcast.net/bballmadness/generator.zip
Midrange bass test
http://mywebpages.comcast.net/bballmadness/Bass.mp3
Fairly low bass test
http://mywebpages.comcast.net/bballmadness/THXSoundBass.mp3
Sine sweep (LOW VOLUME only. you have been warned.)
http://mywebpages.comcast.net/bballmadness/THXTweeterAndBassTest.mp3
Very good tweater test. your ears may not be able to take much of it though.
http://mywebpages.comcast.net/bballmadness/tweater.mp3
THX intro. found at the begining of most dvds
http://mywebpages.comcast.net/bballmadness/iNTRO.mp3
Boston Acoustics - Woofer Cooker (thanks maxvla)
http://www.maxvla.com/woofercooker.mp3
Below 30hz* subwoofer test. will seem quiet if you do not have a good subwoofer.
http://mywebpages.comcast.net/bballmadness/SubwooferTest1.mp3
Audio samples of the world's largest pipe organ (courtesy of Oklahoma Wolf)
Fanfare played by Barbara Fesmire
http://www.acchos.org/mp3/scaledemo.mp3
Sample of It Might As Well Be Spring played by Lowell Ayers
http://www.acchos.org/mp3/might_as_well_be_spring.mp3
Portion of the Widor Toccata from the 5th Symphony, played by Barbara Fesmire
http://www.acchos.org/mp3/widor.mp3
Excerpt from a Sousa's Stars and Stripes played by Lowell Ayers
http://www.acchos.org/mp3/starsstripes01.mp3
Bass Mekanik (scroll down to listen to samples)
http://www.amazon.com/exec/obidos/t...102-8167448-8366536?v=glance&s=music&n=507846
-search amazon.com for "Bass Mekanik". you'll find lots of samples
*edited for additions* post links to any audio recordings you believe test a system well. (with the exception of songs that are illegal to link. dont want anyone getting in trouble)
Tone Generator
Midrange bass test
