Dunno if you guys know about these yet but Sideeffect over at Xtremesystem has been pumping out MOD versions of the A.10 BIOS like crazy =)
Download them here.
And all BIOS's here.
Download them here.
MSI K8N Neo2 Platinum
Bios Rev.1
- Based on 1.A Official
- Default trc = 12 clks & trfc = 18 clks on boot
- Enabled 183 divider
- Enabled 150 Divider
- Enabled S.M.A.R.T by default
- Enabled Bios cacheable by default
- Disabled Temps from showing in bios completely
- Disabled 216, 233, 250 dividers completely
- Disabled ATI/Nvidia Speedup by default
- Disabled Full screen logo and small EPA logo by default
- Disabled Spread Spectrum by default
- Disabled Fast writes by default
Bios Rev.2
- Max Async = 8
- Read Write Queue bypass = 16
- Bypass max = 7
Fixes to Rev1 and 2
- Now all options available in bios will show.
- Full logo and small logo can now be enabled but are disabled by default
- Memory voltage default set to Auto
- Nvidia lan is now on by default.
Ballistix Edition
After extensive testing with athlon 64 tweaker and my Crucial Tracer Ballistix. I found these to be the most stable memory settings. These settings helped me out greatly and make a huge difference to stability.
- Max Async = 8
- Bypass max = 7
- Idle Cycle limit = 64
- DQS Skew Mode = slower
TCCD Edition
Tested by CD1986 with TCCD ram to find most stable timings at maximum mhz. Tried DQS Skew faster slower and off also tested DQS Skew at 255 but the most stable timings were similar to the ballistix but with idle cycle limit at 256.
- Max Async = 8
- Bypass max = 7
- Idle Cycle limit = 256
- Drive Strength weak by default
