- Jun 24, 2014
- TX/CO
I'm trying to finish up my build, but the front panel HD audio header refuses to go into its slot on the motherboard. It'll go in 3/4 the way, and then it won't budge the last little bit - the motherboard starts flexing quite a bit.
I'm positive its in the right way, and that its the correct port.
Is there a trick to help jiggle these guys in, or should I not risk breaking the MB over front audio ports?
