- Apr 13, 2011
I can't get these 2 to overclock together. I have the i5-4670k and MSI z97 gaming-5 motherboard.
I use the OC-genie and it overclocks to 4ghz w/ ram @ 2000mhz. when I disable the OC-Genie and set a overclock, it skips the bios screen, boots right to my RAID0 then after that windows should show up, but it goes to a black screen and on the bottom right it says "A6" or something like that. Just sits there and does nothing, wont boot up.
I tried 3 different youtube videos with people who have the same processor / motherboard. Using there exact settings. For example last settings I used were 44x = 4.4ghz, cpu core volt 1.140, cpu ratio fixed. Would not boot up, then It won't give me a option to enter the bios, skips straight to my RAID0.
Then I have to take the battery off my motherboard and put it back in to get default settings back.
