- Jan 26, 2003
- Land of 10,000 Lakes
I just recently started having problems with the fan on my BBA AIW 9600 Pro. The fan has started to slow down. I am guessing that the bushings/bearings are going out. I have had the card since June 2003, so I am guessing that it is out of warranty. ATI cards do have only a one year warranty right? If it is out of warranty, I will probably end up replacing the stock HS/F with an aftermarket one. Do you guys have any suggestions as to what aftermarket HS/F will fit this card? Also, it has to be able to fit within my Shuttle SFF case, so it cant be one that takes up more than the single rear slot. Any help is appreciated.
