right now I have a DD m6 in a cpu only loop with a rx360, rx120 and a laing dd5/ ek bay rez. There is no air in the system, the processor is at 4.6 @ 1.38 while under load of blend tests in prime 95 (I run prime95 for 24 hours as my end all stability test). The temps on the hottest core hit 75 briefly during one test. the ambient temp is around 20c to 22c in the house. I know what your first question is " why is your voltage so high for that clock", I usually set the voltage as high as im comfortable with then I see what the maximum clock speed I can get stable for that voltage. Personally I think that im running a little hot and I've read that the DD m6 is not as good a performer as I thought it was and I'm planning on replacing it with either a koolance cpu-380I or a ek supremacy. I'm wondering if replacing the block would result in lower overall temps and if so what do you guys think the temp difference would be?
