Hi all,
This is my first time I'm using water cooling.
I'm building a new system with this:
- asus maximus v formula
- i7 3770k (not overclocked yet )
- 2 x gigabyte gtx 760 4g (not water cooled)
- seasonic x-1250 gold
- ocz vertex 3.20 140g (OS)
- ocz revodrive 3 120g (foto editing)
- 2 x WD black 1T (data)
- ek-kit h3o 360 hfx
- additinal 360 xt rad (maybe a bad decision)
- 3 corsair SP120 HighPerf for lower rad (push)
- 3 corsair SP120 HighPert for upper rad (push)
- 3 corsair SP120 Quiet for upper rad (pull)
- additional 11 case fans
- corsair obsidian 900d
Th loop: pump - res bottom - mb - res upper - cpu - reservoir - pump
The pump is mounted at the buttom of the case using ek pump mounting plate.
The plate is on a spunge for the vibration.
Even when I keep the pump with my hand up the air there is a loud buzzing from the pump.
Is my loop ok?
I do not think there are bubbles. I've shaked everything.
Measured the decibels with an iphone app shows around 60db.
Any ideeas what it is wrong?
Thanks,
Theo
Is my loop ok?
Thanks,
Theo
