I'm not saying don't use them. I'm just saying some are more difficult to use than others in reference "supposed to be finger tightened"
This may sound silly but take the fitting and a unused portion of tubing (one that is not attached to anything), make sure the tube is as straight as possible and try attaching it free from anything else. If it goes on smoothly then you know its probably an angle issue. If not it will allow you to play around with it without risking damaging anything else
I was just about to mention the tool. Maybe the ones you have had a tool like the monsoon series. Did you buy them new or from a forum and someone didn't send you the tool?I got a feeling the reason monsoon provide a tool Is for this exact reason. my compressions are tight as hell.
with compressions the hose has to match the fitting size, that's for sure!
