Hey guys. This is not computer related, although i have been hard pressed to locate the information elsehwere, and i was really hoping some of you tech guru's could help me out. First i will start out with what the system is and how it works:
I have a turbohcharged vehicle which compresses air and heats up the air on its way to the motor. Between the turbocharger and the motor, there is an intercooler very similar to a radiator, except the liquid is cooling the air on its way to the motor. The liquid comes from a tank (typically in the trunk) which houses 3-5 gallons of water. So the water flows from the tank to a pump, to the intercooler, to a heat exhanger, then back to the tank. Usually, i will not be under load(highest temps) for more then 7-10 seconds at a time. The air temps from the turbo can reach 400*f.
my idea:
2 part system.
1.Water to intercooler, out to heat exchanger, to copper coil, to pump, back to intercooler to complete cycle.
2.Reservoir with x amount of gallons of liquid, out to pump, out to secondary heat exchanger, back in to reservoir to complete cycle
With this, the copper core will be sitting in a bath of cool water which will have its separate heat exchanger and pump to keep the coolant cool while the already cooled(but probably warmer) water comes through from the main HE through the copper coil. And back out to the intercooler. This allows an additional level of cooling.
thoughts?
Any ideas?
my idea:
2 part system.
thoughts?
Any ideas?
