- Jun 1, 2012
O.k. I came across this company while browsing one day and got curious about the following product:
http://www.dskool.com/edskool/cpu02.html
Now supposedly:
(Copying and pasting the following information from the site)
"Micro Refrigeration CPU Cooler (MRCC) using miniature compressor with coolant R134a to cool the chip directly. MRCC has build-in frequency conversion module to control the cooling capacity from 50W to 400W based on CPU Core temperature. DesunSystems minimized the MRCC size; it could be placed inside computer slot. MRCC be approved has amazing performance by a famous IT company."
The compressor system utilizes FJC 9150 - Extreme Cold R134A High Performance Refrigerant Additive (Got this info from the rep)
Specifications
Cooling Capacity: 50W to 400W
Voltage: 12V
Current: 5A
Noise: 45 dB(A)
Weight: 2.5kg
Dimension: 160x105x130 (mm)
Key Features
Excellent cooling and heat exchange performance
Small size, could be placed inside computer slot
Special Evaporator with better heat exchange performance
Reliable Cooling system technology
Full Control of cooling capacity to match CPU core temperature
Soft tube assembly, easily to install
Standard fixture, easily to replace the existing CPU cooler
I got curious and asked how much it was, the rep said $650.
I tried looking for reviews of the thing but couldn't find a single one.
My problem really is the installation of the thing, does it have a universal block for installation? Is it more effective than a Liquid Cooling Setup?
If it is then the price would be worth it.
I'm having them send the technical specifications to my email address and will place updates here.
Now supposedly:
Specifications
Voltage: 12V
Current: 5A
Noise: 45 dB(A)
Weight: 2.5kg
Key Features
