"glass is NOT a good conductor of heat" - umm, duh? If it was a glass radiator, it would really suck. But in this case the water stays in the res (50 gal fish tank) for about 40 minutes to cool (50gal/~70gph average = 40minutes for complete cycle). Even at half a gallon (if that), a normal heater core holds the water for less than one half of a minute to cool. A 50 gallon tank would easily have as much/more surface area than most of the smaller rads people use here. While glass isn't a great conductor of heat, it still IS a conductor. Everything strives for an equalibrium - a passive glass tank just takes longer than a rad (just needs to be less than 80 times longer than a rad, as it holds the water 80 times longer). A 50 gallon tank has a lot of surface area; most are rectangular, which have a relatively high surface-to-volume ratio. If the water can spend [a lot] more time radiating heat, the transfer doesn't have to be as efficient.
"If it fails at this [saving time/money over conventional means] then why are you wasting your time on a idea that sucks more than what's already out there?" Even at 5 gallons, the water sits in the res for 4+ minutes passively cooling (I'm using a 70 gph working average most people would see). I know for a fact that you can easily go to a flee market/garage sale and find a cheap fish tank [as in much less than most rads]. Many people have them but don't have a use for them atm. Also, one of the main ideas of water cooling is to reduce noise. A pump in a 50 gallon tank is never going to make more noise than an external pump, nor will you really need a fan. If this system [50-100 gallons] was used w/o a top, the evaporation alone could cool the cpu, albiet not as well. Water usally takes energy from the water to become vapor, not from the air.
No offense safemode, but, and I'll even use your quote, I
think your post is "not something that really belongs here [in this thread]". I'm not flaming you, as I can't tell you what you consider a toy idea and what isn't; also, I can't tell if you are just lecturing or saying this idea is impractical.
The fact is that this is EASILY the cheapest way to cool; no leaky barbs/joints or a rad that traps air bubbles, just a smallish fan and a bunch of water. Likewise some people spend many hours modifying thier rads. If you get a used tank, you need only rinse it a few times with cleaner, but you might have to soak a used heater core overnight, and then mod it a bit. They may be the same price used, but the rad needs much more equipment to modify.
All things considered, this rivals a normal rad setup. Cu Rad = compact, fish tank rad = simple.
