- Jan 31, 2013
- Ontario, Canada
So i just downloaded windows 8 free trial from MS onto my Macbook Pro, now there's a program you guys might not know about called Boot Camp Assistant and you can create windows usb keys with it. so i used it to make one, and it says it's supposed to work perfectly when trying to boot another computer, now when i put it into my OSless desktop i just built, nothing happens except for a white underscore flashing in the top left of the screen. i must also add it is set to boot off of USB but i only get that, and it stays with a white underscore. and i have to press CTRL+ALT+DEL to get out of that screen. i don't understand what's going on, perhaps one of you more experienced people can help!
