- Jun 6, 2013
I have had my computer for shortly under one month. I have noticed while I was overclocked to 4.3GHz @ 1.23volts and was sitting at an average of 79C, recently I have begun to notice a major spike in temperature from 79C to 95C, while remaining with the same overclock settings. My room temperature has been the same for the past while already but my temperature still seems to hit the roof.
Computer Specifications:
- Intel i7 4770k Processor (Overclocked to 4.3GHz @ 1.23volts)
- MSI Z87-GD65 Gaming Motherboard
- Kingston HyperX Predator RAM
- Corsair H100i Extreme Liquid Cooler
- Coolermaster Silent Pro M2 1000w Power Supply
- Samsung 840 PRO 128GB Solid State Drive
- Western Digital Black 1TB Hard Disk Drive
- Coolermaster Storm Stryker Case
- Additional Coolermaster Excalibur Fan (mounted on bottom)
Every fan is set to intake except the two top mounted fans. Front and bottom are intake. Back and top are exhaust. The two stock case fans don't seem to push nearly as much air as the Coolermaster Excalibur or as the Corsair H100i fans.
Any suggestions to get this Haswell to run cooler would be greatly appreciated!
Note: At idle with my fans running 100% I am hitting 32C.
Different thermal paste was applied to the CPU, maybe this is the cause of my issues? I just used Coolermaster "High Performance" Thermal Compound, maybe I will give Arctic Silver a go tomorrow!
