Dynamat
YMAN
West Palm Beach, Florida
Hello,
I am very curious about dynamat computer kits for making a
computer quieter. I hear that they are a great choice.
Before I purchase a kit, how do you install it and how well
will it work. If you use dynamat and can post pictures of you
computers dynamat setup I would be greatly pleased.
Also what exactly is it, a thin piece of insulation or...
What are the different kits available and their cost; where
can I purchase it?
Thanks alot,
I learned very much from their site!
Dont Forget, if you have pictures of dynamat installed in your
computer please post them here.
I put dynamat in my case (original :mad: ). The first couple weeks were horrible (the really bad small game me a sore throat). After the smell wore off though it was great... It was much quieter. If you do put it in your case I reccomend using a rubber roller and a hairdryer to get it to stick better. One downfall to dynamat is how heavy it is. My case now weighs about 50+ pounds (kinda hard to carry around to lan parties... but oh well).
let us know how it turns out
Menardsguy said:
Also it seems to insulate my case. My case temps seemed to go up a little. (just a warning)
I understand that dynamat turns vibrations into low-grade
heat?
The computer will never be moved, so a heavy computer
is ok.
FrozenInHI, What do you mean 2 rolls,
are you talking about the 4sq. ft. rolls?
As for the smell, from there site the new dynamat does
not smell. I think its dynamat xtream or somthing on those
lines.
