CountryStrong
- Jul 19, 2014
Hey guys I am getting either a new CPU or a new motherboard. I want every to keep in mind about 2 weeks ago my CPU and MOBO both hit the 130 degree ferinehiet area while playing BF3 with the stock cooler. Since then i have put in a custom water loop, and my tempsa are right around 30 degrees celcius idle. I can only afford one or the other at this time. Looking at the AMD Athlon X4 760k as a new CPU. And the ASUS A88X pro as a new motherboard.
Now my problem is while surfing the web it seems to be a bit laggy. While playing games its got a constant choppy video as you would excpect with extreamly low FPS. So i wanna get some info whether you guys think I overheated my chipset or did the heat do damange to the CPU? Or both?
My Specs:
Asus A55BM-E_MOBO
Asus R7 250x_Graphx
AMD A6 6400k_CPU (overclocked 4.2ghz)
8gb 2x4gb Ram (cheap)
Thermatake T2 750w_PSU
Cooling:
XSPC Raystorm_waterblock
XSPC X20 750_Pump/Res combo
Swiftech 1 120mm_radiator
1/2" primochill_tubing
My Specs:
Asus A55BM-E_MOBO
Asus R7 250x_Graphx
Cooling:
