Look at the bottom radiator's fans is not facing the right position. You should flip the fan over or place the fan on the bottom. Right now your fan are NOT pushing air thru the radiator, rather only pulling it. With low rpm fan, only pulling setup is not the best way. Perhaps your top radiator is setup the same way? If it is, you need to flip them over.
