Trestles126
- Aug 24, 2014
I built a water-cooled danger den AMD pc about 12 years ago. I recently got the bug and in need of a hobby and looking to buy a new ps4 or xbox one i figured to spend 5 times as much and build up a new pc
I just ordered all the WC parts first knowing what my hardware will be so heres the list and plans pictures to follow as well as many questions as times have changed
WC parts
EK 140 tube res with a D5 pump combo.
EK supremacy acrylic (dusted) copper cpu block
EK gtx780 copper acrylic clean VPU block
EK 240 xtx 60mm thick rad
ek white fluid
going to go hard tube acrylic with bits power black compression fittings
as for the components My plan is to build it in the new Phantek mini xl enthoo case when its released laster this month. (if anyone has any release date info or hearsay in the states that would be great)
Asus Gene z79 ROG mobo
Intel haswell 4790k 4ghz processor
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)
a modular PS
and i need to research solid state drives and storage because these didn't exist the last time around. to my understanding they read a lot quicker and are good to house your OP system and programs and have a HD for ur standard files and what not.
I also plan to use my 2009 IMAC 27 inch for a display because its a great display and supports using the video mini dvi hookup. so I'll still use my iMac as a internet browser and to save my photos and normal PC stuff
WC parts
ek white fluid
a modular PS
