Notices
Overclockers Forums > Hardware > Motherboards > AMD Motherboards
AMD Motherboards
Forum Jump
can i change bus from 100 to 133 in bios on EPoX 8KHA+
Thread Tools
Old 12-13-01, 09:37 PM Thread Starter   #1
ThePunkGeek
ThePunkGeek's Avatar
or jumpers?
if bios can i can a small explination how thx
__________________
My Heatware
Proud Member Of Folding@Home! Team 32!~ Join us we need your help!
ThePunkGeek is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 12-14-01, 12:32 AM   #2
sealworx
Since your using an Athlon xp I think you should change the FSB setting to 133 from the jumper in th board. The 8KHA+ comes with its FSB setting at 100 when u take it out of the box. It is up to you then to change it to the 133 setting.
Hope it helps.
sealworx is offline   QUOTE Thanks
Old 12-14-01, 08:26 AM Thread Starter   #3
ThePunkGeek
Re: can i change bus from 100 to 133 in bios on EPoX 8KHA+
Quote:
Originally posted by ThePunkGeek
or jumpers?
thats what i did thanks
__________________
My Heatware
AMD Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
