Recently added:
512mb stick (now a total of 2 gigs, 2 same brand, 2 different, but all same timeings and speed)
250 gig hdd (I Think this is it)
Silverstone 500watt element psu
The reason why I think its the HDD, is because even with my overclocked CPU and memory, both run stable, but I get random crashs from windows saying its a new peice of hardware thats ****ing it up. Ram, i think now, and psu, how would that be? The HDD is SATA2 and my P5P800 i think said sataII was the top slot, so I hooked it up. I install everything fine, but the weird part about it is that when I install stuff, its almost the same speed as my other hdd (40 gig ata). But, whenever I unstall something (gta san andreas, as it would crash on load up), it uninstalled almost 5 gigs and deleted them in less then a few seconds. While, it took around 5 minutes to install. What would happen if it hooked the hdd up to a sataI slot on my mobo.. will it **** anything up? Even if its not that.. what else could it be?
Edit:
I've never gotten below 90,000 on that test. Even with 1 gig ram, lower CPU clock speeds and ram speeds, same gpu clocks, i still got 93,***
Edit:
