- Dec 6, 2013
- Baden, Austria
Hi,
At the moment I am using a Asus P8Z68-V Pro Gen3 w i7-2600K@4,6GHz w 2x4GB Kingston 1333 9-9-9-24 value RAM and a 850W PSU.
The RAM is from my old 1156 system and worked fine at 1600 9-9-9-24 for a long time. Now I put it into my new system and started playing around a little bit with latencies, frequency and voltage. Suddenly I ran into stability issues, did Memtest+86 and found errors in the first RAM slot. I removed the RAM and tested again - no errors. Put the removed RAM back and again no errors. So I kept using it and continued playing with the settings until I again run into stability problems. Strange thing was that even after setting everything to default in the bios the stability issues remained and windows based Memtest immediately found errors. Did Memtest+86, two rounds, no errors at all. Swapped RAMs, and no errors in windows-based Memtest. Now everything runs fine but have no clue what was going on.
The way I ran into stability issues was that I tested both directions; stock frequency, stock voltage with as low as possible latency. Brought it down to 7-7-7-17 T2 and stable with all tests. Aida, IntelBurn, Memtest. Tried to tweak further with T1 --> crash.
Other direction; frequency as high as possible with adjusted latencies and voltage but not higher than 1.6V. Reached 1600 as expected - everything fine. 1866 --> crash.
In both cases these crashes led to the strange behaviour that no matter what setting I used afterwards the system remained unstable until I started taking out the RAMs and playing around with them.
Any ideas what could be going on?
Chris
Chris
