- Apr 15, 2007
Hi Group,
I'm not intending on overclocking my system but I thought this would be the best place to get advice on my problem.
System:
bought in November 2006
Intel D975XBX motherboard
OEM heatsink/fan
running 3 WD Caviar SATA 250GB HDs on RAID5
430 Watt power supply
2 LG DVD/CD burner combodrives
dual booting Win Multimedia Edition and Vista
PC worked well until Friday night when it shut down without warning. Upon reboot, process reported it had shut down due to a CPU overheat problem.
It continued booting part way into XP then shut down again. I let it cool for a while then F2ed into CIMOS. Temp was 63C and soon went to 97C.
Shut down, cleaned what little dust there was out, removed heat sink/fan, lapped top of CPU and bottom of heat sink, cleaned mating faces with alcohol, applied a thin film of Heat Sink Silicon Compound, reassembled, added a 120MM case fan and restarted.
I'm still ranging between 63 and 97C at idle. Any ideas?
Thanks in advance ,
Randy
System:
OEM heatsink/fan
Thanks in advance ,
Randy
