Notices
Overclockers Forums > Software > Microsoft Operating Systems
Microsoft Operating Systems Microsoft Operating Systems and Applications
Forum Jump
Newbie Question, what's wrong?
Thread Tools
Old 08-21-02, 09:12 AM Thread Starter   #1
DreamingWolf
Wheel Walker
DreamingWolf's Avatar
Unhappy Newbie Question, what's wrong?
Help, I've been making my first forays into overclocking and hit a snag. My system posts, my boot loader (LILO) runs, but neither of my OS's (WinXP pro, Suse Linux 8.0) will load. Will boot to floppy or CD and harddisk diags say my HDs are fine. Did I fry my chip, Mobo or just mess up my OSs? Is there any chance I hurt my video card? Oh yeah, WinXP did load in safe mode but even system restore did not bring up the regular mode. HELP!!!
DreamingWolf is offline   QUOTE Thanks
Old 08-21-02, 09:24 AM Thread Starter   #2
DreamingWolf
Wheel Walker
Forgot to add
Forgot to tell ya 2 things, no clue what kind of mem I have, but I had just flashed a beta bios from Soyo that had a voltage setting in it, but that option is missing from the bios now. How could that happen???
Old 08-21-02, 10:04 AM   #3
Exar Jun
Exar Jun's Avatar
You might want to move this one down to the OS forum to get better help.
__________________
e6400 - Big Typhoon
P5B Deluxe wifi
Ballistix 8000
x1950xt - 256
Corsair hx520w
Heat
If you don't fold...click below
F@H Team 32
Exar Jun is offline   QUOTE Thanks
Old 08-21-02, 10:13 AM   #4
donny_paycheck
Inactive Super Quad Mod
donny_paycheck's Avatar
It sounds to me like an OS problem. You definitely didn't fry your CPU or mobo if it POSTs and boots to the OS booting portion without trouble. You might have corrupted your hard disk(s).
Try posting this in the Operating Systems section like Exar said. You'll probably get more responses there.
WELCOME TO THE FORUMS!
__________________
Core i7 920 @ 4 GHz, 1.35v
Corsair Nautilus 500 w/DD BIX radiator swap & Apogee GTX
Asus P6T
6GB Corsair Dominator
XFX GeForce GTX 285
WD Raptor 150GB / Hitachi 1TB
Antec P182 / PCP&C Silencer 750
Samsung 2232GW
Sic vis pacem, para bellum.
donny_paycheck is offline   QUOTE Thanks
Old 08-21-02, 10:19 AM   #5
Exar Jun
Exar Jun's Avatar
My bad Wolf.
Welcome to the Forums!!!
__________________
e6400 - Big Typhoon
P5B Deluxe wifi
Ballistix 8000
x1950xt - 256
Corsair hx520w
Heat
F@H Team 32
Old 08-21-02, 03:41 PM Thread Starter   #6
DreamingWolf
Wheel Walker
found the problem
Thanks for the welcome and the advice, however, it turns out I fried my video card (pny g4 t4600 / ouch) digging in the case to get at the cmos reset jumper. DRAT
Anyway thanks again and you probably be hearing alot more of my oopses in the coming weeks.
BTW any ideas about the vcore setting that 'vanished' from my bios setup screens??
Old 08-21-02, 05:25 PM   #7
macklin01
Computational Oncologist / Biomathematician / Moderator on Vacation, Ph.D.
macklin01's Avatar
Welcome to the forums.
Hmm, I know that some mobos support dual BIOS's -- that is, they have a current and a backup BIOS on them. Not sure if yours is one of them.
Also, what is your FSB right now?
If your OS doesn't load with the overclock, it might just be that your northbridge/IDE controller/hdd doesn't like the overclock.
For example, on my system, my highest attainable overclock is 156 MHz FSB. At that range, the PCI divider is 1/4, so the PCI bus runs at 39 MHz. (As opposed to 33.333 MHz.) If I push it any farther, I get file errors when loading the OS from the hdd, but not from CDROM, just as you describe. (Both Linux RH 7.3 and WinXP Pro)
So, once you get your poor video card back in order, boot into BIOS and decrease your FSB and see if that does the trick.
Good luck! -- Paul
__________________
My heatware (macklin01)
Need image I/O for your science apps? Try EasyBMP
My biomedical research: Mathematical Cancer Modeling & Simulation
I'm on vacation as a moderator as I devote more time to my faculty position.
Thank you for your understanding if I don't respond to your PM. -- Paul
macklin01 is offline Folding Profile Heatware Profile   QUOTE Thanks
Old 08-22-02, 02:44 AM Thread Starter   #8
DreamingWolf
Wheel Walker
Hey Paul, thanks for the tips. FSB is presently at 135. I stuck in an ancient 16M 3dfx card I had and the system booted right up w/ no trouble. Before the demise of my real card I had discovered that @ default voltage I could only get the FSB to 137 and still be stable, that my Mobo only liked upping the voltage by 0.025, but with that I could reach the low 140s. I can't find where in the bios to adjust PCI divider, (also have to learn how to properly tweak it when I do find it)
BTW where should I go to get good diagnostic tools that I can put on a bootable CD that don't need a shell to run so that if (make that when) I mess up again I can find out right away whats up???
Thanks again for the welcome, you guys are GREAT!!!
-D
__________________
Respect always the pathways that others follow in their spiritual journey. --DWolf
Patience is the willingness to review and revise your expectations. --DWolf (At least I don't think I've ever seen it elsewhere)
"Science has sometimes been said to be opposed to faith, and inconsistent with it. But all science, in fact, rests on a basis of faith, for it assumes the permanence and uniformity of natural laws - a thing which can never be demonstrated." --Tyron Edwards
Don't know where to start? Try the forums search function, or just PM me and I'll help or find who can :D.
Has someone helped above and beyond? Post a Thank You
here
Asus A8N32-SLI Deluxe, AMD x64 4800+, 4G Corsair 3500, 2X BFG7800 in SLI mode, 2X 24" Dell flatpanels, Audigy 2zs platinum, & enough fans to hover the space shuttle:)
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
