- Jun 1, 2012
I need a little help with some aesthetic work I'm going to be doing on my new setup:
I was able to acquire a limited edition Cooler Master CSX Spartan V1 Stacker 830 Case
(seen here)
http://www.revolutionpc.net/store/Cooler-Master-CSX-Spartan-V1-Stacker-830-Case-Limited-Edition.html
Thankfully I was able to get a massive discount on it
The original owner didn't use it that much and its still relatively brand new within the box (it'll arrive within 35 days since I'm using ocean freight shipping).
Now my semi-ambitious plan is to use chrome colored 1/2 inch tubing for my watercooling setup.
Combined with the case I expect it to look awesome, especially when combined with a Rampage 3 Extreme MoB and and an Asus Ares (yeah the parts are now considered old but they're brand new, never used and I' m going for a certain theme to this case....Ares+Sparta = WIN)
Now I've looked everywhere online, no one seems to be selling chrome colored tubing so I'm going to have to make it myself.
Here's a video example of the process I'm going to use
however, instead of the spray used there I plan to use Killer Chrome (costs around $129 for a set)
http://www.alsacorp.com/products/killercans/kc/killerchrome.htm
Now this type of spray can work on a variety of surfaces ranging from tiles, metal, plastics etc.
Here's an example of the color I'm going for:
So I'm willing to bet it'll work on the plastic surface of a tube.
Now to make it look like I used actual chrome tubing I need a 1/2 type tubing that's flexible but has a certain rigidity (more so than what you would normally see in an average watercooling loop) to it to get the "made from metal look".
If you know of any type of tubing that fits the bill please let me know.
Yes I do realize that covering the tube in paint makes it impossible to see the flow rate so what I'm planning to do is to measure, cut and place the tubing and complete the entire setup, then take it apart, coat the tubing then put it back together with a flow meter so that I can check the flow rate.
Its a rather simple project but the effects should look epic:
(seen here)
