Notices
Overclockers Forums > Hardware > General Hardware
General Hardware Discuss your new build and gather upgrade suggestions. And if your question doesn't fit anywhere else...it goes here.
Forum Jump
my barton overlcocking.....
Thread Tools
Old 08-24-03, 02:13 PM Thread Starter   #1
highacker
highacker's Avatar
Talking my barton overlcocking.....
hi i just finished my new rig and today i started to push it to the limits, started with the fsb, and got it all the way up to 191 completely stable but too hot, around 52 C load, it pulled 17397 3d marks, wich i think it wasn't too bad, the memory is running at CAS 2 latency and i just loved it, any suggestion for good air cooling?
highacker is offline   QUOTE Thanks
Old 08-24-03, 02:14 PM Thread Starter   #2
highacker
highacker's Avatar
Old 08-24-03, 02:16 PM   #3
Deathknight
Deathknight's Avatar
If you are looking for some good air cooling thermalright has the best heatsinks around. The sk-7 is a great bang for the buck. The slk-800 and slk-900 provide even better cooling, for more cost of course.
Btw you probably will get a better response sticking this in the amd cpu or cooling forums than the video and sound section.
Deathknight is offline   QUOTE Thanks
Old 08-24-03, 02:22 PM Thread Starter   #4
highacker
highacker's Avatar
ok be right there... thanks
Old 08-24-03, 03:33 PM   #5
Jognt
All round good guy
Jognt's Avatar
that........is SOME rig!
__________________
Are you new? Introduce yourself!
Current rig:
Fractal Design Define R4
Asus P8Z77-V
i5 3570k @ 4.3 offset OC w/ TR HR-02 Macho rev.A
2 * 4GB Crucal DDRIII-1866 @ XMP 9-9-9-27-47-2T
2x Asus GTX670 (SLI)
Crucial M4 256GB SSD | 4x Seagate 2TB in RAID10
BeQuiet Dark Power Pro 600W (Yes, that is enough power)
Remove your fangrills!
Jognt is offline   QUOTE Thanks
Old 08-24-03, 05:34 PM   #6
Lord_Zoltan
nice rig, how do you like the 9800pro?
Get a better heatsink, 800u is good , 900u is probably better in the way you can puta 92mm fan so it would be quieter. And check you case airflow
Lord_Zoltan is offline   QUOTE Thanks
Old 08-25-03, 12:57 AM   #7
BigRed
Caffinated Member
BigRed's Avatar
10 Year Badge
Quote:
Airflow? Whats that?
__________________
These products not tested on animals. But if you've got pets, and want to do your part for scientific inquiry...
How far over stock could an overclocker clock, if an overclocker could clock over stock?
Back in the days of the Greeks and Romans whenever the people where confronted with a single or chain of Destructive events on the Epic scale they took it as a sign of the gods displeasure with how things are going then promptly deposed (killed) the leader of the time.
AHHH the good ol' days :D
BigRed is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
