I am so happy I found an amazing deal on a gaming rig
BackBreaker
Disabled
http://www.buy.com/prod/gateway-gt5...64-x2-4600-dual-core/q/loc/101/209897475.html
combined with the visa credit card offer purchase that saved me 30 bucks the total including tax and shipping came out to 308 bucks. now the only thing I need to be able to play basically every single game at full resolution is a graphic card and it has many expansion pci slots for those as well. The only thing that's kind of weird is they say shipping is free yet they charged me.
Features
Microsoft Windows Vista Home Premium operating system
AMD Athlon 64 X2 4600+, Dual Core processor with AMD64 Technology
then right below..
Tech Specs
Processor Intel Core2 Duo E4600 dual core processor
Each core operates at 2.4 GHz
Which is it?
thats not the only glitch in their descriptions:
lets play a little game shall we?
one of these lists is not like the other one....
Code:
Features
	[COLOR="Yellow"]AMD Athlon 64 X2 4600+, Dual Core processor with AMD64 Technology
	2 512 KB L2 cache
	2000 MHz system bus
	NVIDIA GeForce 6150SE chipset[/COLOR]
	[COLOR="DarkOrange"]2048 MB DDR2, 533 MHz, (PC4200) dual channel memory (two 1024 MB DIMMs)[/COLOR]
	[COLOR="MediumTurquoise"]320 GB, 7200 RPM, SATA II hard drive[/COLOR]
	[COLOR="Lime"]DVD RW, 16X multi-format dual layer drive[/COLOR]
	15-in-1 high speed digital media manager
	Docking bay for optional Gateway 2.5-inch removable USB hard drive
	Integrated 10/100 Mbps Ethernet LAN
	56 K ITU V.92 ready fax/modem
	Elite multimedia keyboard
	USB optical 2-button wheel mouse
	USB powered stereo speakers
Tech Specs
	[COLOR="Yellow"]Processor Intel Core2 Duo E4600 dual core processor
	Shared 2 MB L2 cache
	800 MHz front side bus
	Chipset NVIDIA GeForce 7100[/COLOR]
	[COLOR="Orange"]Memory Installed: 4096 MB DDR2, 667 MHz, (PC2-5300) dual channel memory (two 2048 MB modules)
	Expandable to: 4 GB (two DDR2 DIMM slots)[/COLOR]
	[COLOR="MediumTurquoise"]Hard Drive 500 GB, 7200 RPM, SATA II hard drive[/COLOR]
	Support for up to two hard drives
	[COLOR="Lime"]Optical Drive 18X DVD +/- RW super multi-format dual layer drive with LabelFlash (up to 8.5 GB)
	Write max: 18X DVD-R, 18V DVD+R, 6V DVD-RW, 8V DVD+RW, 8V DVD+R DL, 8V DVD-R DL, 12V DVD-RAM, 48V CD-R, 32V CD-RW
	Read max: 16V DVD-ROM, 48V CD-ROM[/COLOR]
	Media Card Reader 15-in-1 high speed digital media manager supporting the following:
	Compact Flash (CF) I, II
	IBM Microdrive (MD)
	SmartMedia Card (SMC)
	Memory Stick (MS)
	Memory Stick Duo (MS Duo)
	Memory Stick PRO (MS PRO)
	Memory Stick PRO Duo (MS PRO Duo)
	Secure Digital (SD)
	Mini Secure Digital (MiniSD)
	Multi Media Card (MMC)
	RS Multi Media Card (RS-MMC) (need adapter)
	Multi Media Plus Card (MMC Plus)
	Multi Media Mobile Card (MMC Mobile)
	xD-Picture Card (xD)
	[COLOR="YellowGreen"]Video Integrated NVIDIA GeForce 7100 graphics[/COLOR]
	Up to 256 MB shared video memory
	Audio Integrated 8-Channel (7.1) High Definition Audio
	Network Support Integrated Realtek RTL 8211BL 10/100/1000 Mbps fast Ethernet LAN
	Modem 56K ITU V.92 ready fax/modem
	Add-in Card Slots One PCI Express 16 (graphics interface)
	One PCI Express 1
	Two PCI conventional
	External Connectors One PS/2 keyboard port
	One PS/2 mouse port
	One VGA monitor port
	One HDMI port
	Six USB ports (four rear, two front)
	One RJ-45 Ethernet LAN port
	Eight audio jacks (six rear, two front)
	Drive Bays Five total:
	Two external 5.25-inch
	One external 3.5-inch (with a docking bay for optional Gateway 2.5-inch removable USB hard drive)
	Two internal 3.5-inch (hard drive)
	Physical Dimensions
	(H W D) 15.5 7.25 16.5 inches
	90 Day Gateway Warranty
seems to me they cant decide which computer it is
I read some good reviews of the site though:
http://www.epinions.com/content_142840336004
and either way any of those 2 set ups Im happy, you cant find a dual core processor for anything lower than 400-500. The 200-350 dollar comps for black fridyad eals, etc. I was looking at have single cores of like 2 ghs or crap like that.
ya but there is a HUGE HUGE diff in performance!!! between the 2... i would be a little warry of that and contact them first before buying anything..... or if anything, get the rig, save the site, say you didnt get the system you ordered and charge back.
so which one would be better? And will the lower performance one be still good for today?
8800 GT. You should be able to find one used for that price. Can someone fix the multiple posts? Complete accident.:eh?:
not new. Id have to ebay it. And I have no clue about the pci slots as the last time I upgraded a card it was agp and my power supply was almost not enough for it. So Id have to know for sure it will work or probably pay 40 bucks for bestbuy to do it :(
Also when you put a new graphics card in you may need to install a new psu which will run you 50-100$.
