- Feb 11, 2006
I bought more ram for the setup in my sig. I could no longer purchase the ocz I already had so I bought some gskills. Both are ddr2 but other specs differ. How do I get them both to work.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
DDR2 800 (PC2 6400)
Timing 5-5-5-15
Cas Latency 5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2RPR10664GK
Timing 5-5-5-18
Cas Latency 5
Voltage 2.1V - 2.2V
DDR2 800 (PC2 6400)
Timing 5-5-5-15
Cas Latency 5
Timing 5-5-5-18
Cas Latency 5
Voltage 2.1V - 2.2V
