wild_andy_c said:
After flogging this board for a whole 3 days, I have come to the conclusion this indeed is not BS. Yes, you can hit 250 fsb, but 3D stability is another thing. I did hit 250 and could probably boot higher, using ADATA PC450 at 3-4-4-7, however it was not 3D stable, though it would pass Sandra Memory and Cache-and-Mem OK (3700+ buffered).
I did get my 2x512 MB XMS3500 stable at 231, 2-2-2-5, CPC Enabled, at the max 2.9 VDIMM of the board which is more like 2.816-2.83 actual. This is truly remarkable. Even on my P4 boards, I could not run DDR462 at that voltage. The board can bench all four 3DMarks here. As these are my worse pair of seven XMS3500 sticks, dare I say 235-240 is possible at that VDIMM???
Couple of tips on using this board:
1. Need the L12 mod to get any ram above 218 or so Memtest clean
2. The Merlin BIOS got my BH-5 from 223 Memtest clean to 231
3. Doesn't need an APIC-disabled WinXP like the NF7-S
4. Partitions and formats drives 3-4x faster than an NF7-S
5. Is definitely better at +2.0 VCORE overclocking than three NF7-Ss I tried
6. Board undervolts pretty severely: 2.075 is more like 2.02; similar story with the VDIMM
Ram testing, max overclocks (must bench all four 3DMarks):
2x512 XMS3500: 231, 2-2-2-5/9/11 (no diff in bandwidth)
2x512 Ballistix PC4000: 236, 2.5-2-2-5
2x512 PQI TCCD: 232, 2-3-3-6
2x512 ADATA PC450: 238, 2.5-3-3-6
2x256 OCZ PC3700 Golds, Rev. 1.0 (this is actually DS ram): 238, 2-3-3-6 (surprising)
With the Merlin BIOS, all ram tested has a 238 or so cap, 3D stable. I can run the Ballistix at 244 Memtest clean, but won't clear all four 3DMarks till 236. I know I can run most these ram much much higher, like 260 on the PQI TCCD on P4 boards.
This board is clearly superior to the NF7-S based on two weeks testing of that board. While I could run ram Memtest clean >230 fsb, and could get Sandra Mem and Cache-and-Mem screenies, the Abit would not bench all four 3DMarks till 223 or 222. I tried several modded BIOSs by TicTac, Trat, and Merlin to no avail. At best it would clear 2/4 of the 'Marks.
How well did the 8RDA3+, Rev. 3.2 overclock a stubborn XP2100? To 2500 mhz at 2.02 volts. In comparison, the NF7-S needed 2.1 volts. With a better mannered CPU, I got an XP2600-M to 2600 mhz at 1.65 actual VCORE, running 2x512 Ballistix PC4000 at 236x11, 2.5-2-2-5 at 2.77 VDIMM (3590/3390 bandwidth). Max overclock on this excellent Mobile is still to be determined. Cooling is a HC200.
I picked up another Rev. 3.2 8RDA3+ and am pretty much getting rid of all my archaic NF7-S boards.
I'm hoping something can be done to relieve the 238 fsb cap of the 8RDA3+ for 3D stability, but that may be due more to my insistence on running 2x512 MB ram with CPC Enabled.
