Hello and happy holidays everyone!
The other day I built pretty much a new PC (specs on signature), the only thing I'm using from my previous build is the GPU and peripherals. So the issue is that on my new build my headset's mic is producing a lot of static (my friends on Skype have been complaining about it!). It worked well on my previous build and it still works well with no static on my family's laptop so I know the mic didn't get defective.
I tried using the latest sound drivers from the Asus site and then Realtek's and I tried messing with the Windows and Realtek sound control panels. The mic level is at max and the sound boost only makes the static worst. The noise supression option makes the static sound less annoying but it's still pretty bad.
I found someone with a similar problem (different mobo/soundcard from Realtek also) and they said the issue was caused by the mobo sitting too tight against the I/O shield. Well, I had in fact applied a bit of pressure to my mobo for it to align with the stand-offs because of the stupid padding on the Q-shield from Asus, so I thought that I might have the same problem. However, I removed the I/O shield and everything's the same...
This is my headset: Plantronics GameCom 367
Any suggestions? IMO it sounds like my mobo may have a defective soundcard but I'm no expert so any input would be appreciated!
EDIT: Forgot to say a few things... Using the front panel or plugging the mic directly into the mobo doesn't seem to make any difference. I also tried using a USB adapter and it seems the issue remains. It sounds the same as when I use 0 boost with no adapter but there was no option to change the boost level so I couldn't test it that much.
