I would like to create a sysprep with Server 2008 R2 and Server 2012. I only have very limited SSD space available, and I will often need several instances of the same OS running in a domain.
I would like to host the sysprep OS files on the SSD, and then run the rest of the OS from a HDD. Does this provide a big performance boost? I'm not entirely sure how it works, but the way I see it, the OS gets installed and runs from the SSD, then only the changes get read and written from/to the HDD (I will be creating a linked clone following the instructions from here).
So basically I intend to have the "big" files on the SSD, and the small folder (it's usually only around 15MB to start off with until it grows) on a disk drive. I often have to set up new servers and it's a real pain to have to keep copying and pasting the same VM over and then changing the MAC address etc. Will the disk drive bottleneck the SSD to the point where any performance boost is negligible?
