[rant]
I have mixed feelings here, at certain settings a 1090T will stomp a BD in terms of effiency (default is a good example). At stock voltage (1.30v) my BD (8120) will overclock to 4.0Ghz+, where my 1090T requires 1.4625v...a definite loss in terms of points/watt for Thuban when it is overclocked. BD then looses when pushed beyond that trying to catch the Thuban because the BD requires higher clock speed for the same amount of work (clock for clock X6>BD). The reason I believe BD fails so bad is because the default voltage is far too high, both the Core and the IMC on my BD can be massively undervolted and remain stable where my Thuban can be undervolted at stock speed but only slightly (one bump down for both the Core and IMC voltage). Also look at turbo of BD, on mine it jumps to 1.400v for 4.0Ghz, it can easily do that on 1.30v (default) and pass a battery of Intelburntest. Perhaps it's the poor yields that resulted in such bad voltage selections I don't know but it is bad on mine and makes BD look a lot worse than it is.
To sum it up my BD does more work (edit: in folding at home, rosetta is most likely the same) then my Thuban does at ~225W, rest of the system held constant.[/rant]
Yes I'm an AMD fanboy, and no I'm not saying this for that reason alone, there are plenty of BD's being overclocked by~1.0Ghz on stock voltage and stability tested.
If you want to help AMD out a bit buy BD or Thuban. If you're after points/watt and/or just raw points buy an i7 2500K or 2600K, they overclock like crazy and use less power and generally do more work clock for clock.
