- Jul 26, 2004
Ok I have been running a water cooling setup for a few months now , I need somthing new to play with and dont have much $$ right now . So I figured Y not try and setup a chiller but i know nothing about this so I have come to the pros to ask for help .
My WC loop is D5->DD TDX->DD Maze4->BlackIceExtreem III->D5
So first question is where would it go in my loop Before or after the rad? Do i even need the rad in the loop when using a cooler? wouldnt the rad just be putting Ambient air into the loop causing higher temps ? Or is it best to Put the Rad in the sub zero container ?
Next question with a cooler should I insulate around the cpu block and the gpu ? Or will it not be cold enough to need any thing ?
Coolant do you need more when running a cooler so the water wont freeze ? what % would you recomand ?
Now that those questions are out of the way the cooler its self. I plan on trying to find somthing that is old for free(on side of road or @ junkyard) for this build as i have said it is a low cost build . So what should I keep my eyes open for? Old Ac units? old Dehumidifiers? is one better than the other? (get colder) . Now for the container what do people like to use? I figured i could find a old picknick cooler use whould this be suitable ?
This isnt somthing I want to rush into so any other thing that i didnt ask but i should have please inform me
