I bought a new case to transfer my PC to, and need some help diagnosing a potential power problem.
I removed all the components from the old ATX case, and installed the motherboard and PSU in a new mATX case (cheap Casecom).
Running just the motherboard/CPU/case fan with no drives, all seemed to work ok.
I then started connecting a few more things, which is when i ran into problems. I installed a brand new SATA DVD/RW drive. All POST'd fine and detected in BIOS. I disconnected the drive and powered on again, and noticed after about 0.5 sec, the power went off.
After turning off the PSU and disconnecting the case fan, it all seemed to work ok again. I tried it with the fan back on, and it worked fine. On the next power cycle it did the same thing again and turned off.
The issue appears to be random, as it's happened with the fan / DVD drive connected / disconnected at random intervals.
To double check, I disconnected everything, and re-seated the PSU connector on the motherboard, and powered on with no CPU 4-pin power).
PSU powers on fine. Tested this 3 times, worked every time.
I then connected the 4-pin CPU power, and it turned off after 0.5 sec. After another power reset, it worked fine, 3 times in a row. I then connected the case fan - it turned off after 0.5 sec.
I can't seem to identify what is causing the issue as it seems random. One thing that is consistent (might need more testing), is the PSU runs fine on it's own, with nothing else connected (inc. CPU)
NOTE
I had noticed a couple of times when all was powered on and working, that the case power light would flicker/dim, and there would be a 'clicking' coming from the PSU in unison. I immediately powered it off when this happened.
It sounds like it might be a faulty PSU, but it's inconsistent, so don't know if it's motherboard / cpu related as well? Could the power surge have damaged the motherboard/CPU etc?
Hope you can help identify the problem.
Specs:
NOTE
Specs:
- PSU: Casecom ATX 500w
- Asus P5GD1-VM
- P4 Prescott 3.4GHz
- 2 GB RAM
