Notices
Overclockers Forums > Hardware > Video Cards > AMD (ATI) GPUs
AMD (ATI) GPUs
Forum Jump
Deperate need of help.
Thread Tools
Old 10-04-06, 06:35 AM Thread Starter   #1
Ecca
Ecca's Avatar
I have a MSI x1900xtx and games play fine but videos play inverted like blue, teal and yellow. I cannot fix this I restored the settings to default, got new codes and nothing. Please I need help bad
Ecca is offline   QUOTE Thanks
Old 10-04-06, 08:16 AM   #2
rainless
Old Member
rainless's Avatar
Quote:
Have you tried simply uninstalling and then reinstalling the drivers? Better yet... upgrade to NEW drivers.
|| Edited by S-N ||
Mate, let us keep this on topic. You have a pm.
__________________
Core 4 Q9550 @4003mhz 1.30v
Core 2 Duo e8400 @ 4.6ghz 1.328v (E0 Stepping)
Core 2 Duo E6400 @ 3.8ghz 1.525v
Asus P5Q Pro 2002m @ 515x9 .63x 1.52
OCZ Fatal1ty Edition 4GB DDR2 5-4-4-18 @ 2.18v w/OCZ XTC Ram Cooler
Corsair 750TX PSU
Sparkle 260 GTX (65nm, 216) 696c 1512s 999mem
BLOCK: Swiftech Apogee GTZ RAD: BIXII REZ: MCRES-Micro rev2 PUMP: Pondmaster 750 FAN: 2 HS Yates CONTROLLER: Modified Evercool WC-202
rainless is offline   QUOTE Thanks
Old 10-30-06, 10:13 AM   #3
zzgocartman
||Edited by S-N||
This is a technical forum. You are taking this thread off topic. Please refrain from doing so henceforth.
__________________
New 840 build
Mobo gigabyte GA-MA78LMG-S2
CPU Phenom II x4 @ 3906.1 @1.44v stock air cooling cinebench stable
Generic Ram 2x2gb @11-11-11-29
672.0mhz
more to come
zzgocartman is offline   QUOTE Thanks
Old 10-30-06, 07:38 PM   #4
Tophinater
Tophinater's Avatar
NY here I come!
Also, can you post a screenshot possibly? Be easier to see what your talking about.
Tophinater is offline   QUOTE Thanks
Old 10-30-06, 07:43 PM   #5
Xtreme Barton
Xtreme Barton's Avatar
what are you playing videos with ?
Xtreme Barton is offline   QUOTE Thanks
Old 10-30-06, 07:45 PM   #6
XxNightfirexX
XxNightfirexX's Avatar
Heh, I knew there had to be something good about this state.
Are you having this problem with different video players? If you only use WMP 9/10, I'ld suggest installing WMP Classic and try that.
__________________
~Folding for our Future~
~F@H Team 32~
ASRock Z77 Extreme4
i5 3570
2x4gigs G-Skill Snipers
Saphire Radeon HD 6870
Antec Earthwatts 650
LG Flatron E2241
XxNightfirexX is offline   QUOTE Thanks
Old 10-30-06, 07:51 PM   #7
Super Nade
SU(3) Moderator
Super Nade's Avatar
What PSU do you have? Do you have proper cooling? Did you attempt to replace the TIM?
Moved to the ATI section.
__________________
Motherboard Repair Tutorial || Power Supply Repair Tutorial || A Closer Look at PSU Signals ||
Understanding SMPS Technology
|| ASUS P5K Capacitor mod || Kernel Compile Guide || Guide to Wiping an SSD
Build in progress
ASUS Maximus Hero || i5-4670K || Crucial M500-480Gb || Antec HCP-850M || ASUS GTX 750Ti || Carbide 300R || Coolermaster Glacer 240L
Super Nade is offline Author Profile   QUOTE Thanks
Old 10-30-06, 08:25 PM   #8
Shell
Shell's Avatar
You own an ATI card... have you ever had the hardware decode crap on you? Because that's exactly what is does from what she's describing... or mabe I just like to pick at my drivers too much...
If everything else is working fine to your video card... that's likely the problem, an annoying one that can only be fixed if you replace all the decoder software that's built into the drivers.
Use driver cleaner and remove everything ATi from your HDD, then re-install the latest driver release.
If that's not the problem... more details will be needed.
Can you try to play a video and take a screen shot? That'll confirm what I belive is the problem.
And what media player do you use? If it's not WindowsMP it may not be working properly with ATI's hardware decoder.
__________________
FX-6300@4.5GHz, 7770, 2x4GB DDR3-1600 CL8, PCP&C 400w, 2x1TB
i5-4690K@4.5GHz, 7850, 2x4GB DDR3-2400 CL10, Seasonic G-550, 2x1TB
Shell is offline   QUOTE Thanks
Old 10-30-06, 08:48 PM   #9
Super Nade
SU(3) Moderator
Super Nade's Avatar
Ooh good point! I misread the first post skipping over "video". Good catch Shell!
__________________
Build in progress
Old 10-31-06, 01:18 AM   #10
Brando
Brando's Avatar
Go into Catalyst advanced. Click on AVIVO. Click on "all settings". Scroll to the bottom. Uncheck "Windows media video acceleration".
__________________
[]Intel 3570k 4.4ghz~Asus P8Z77-V pro~TRUE spirit 140 power[]Mushkin Blackline 2x4gb[]Gtx 780 direct cu II oc[]Dell U2713HM[]Samsung 840 Evo 500gb~Spinpoint F3 1tb[]Pioneer BDR-206[]Corsair AX850[]Fractal Midi R2[]Leopold Tenkeyless~Deathadder 2013[]Harman Kardon HK990~Denon AH-D7000[]
SELLER FEEDBACK
PROLIMATECH MK-26 VGA COOLER FOR SALE
A FEW FANS FOR SALE
Brando is offline   QUOTE Thanks
Old 10-31-06, 02:45 AM   #11
wingVTA
wingVTA's Avatar
Download the right codec!!!
^^ It is a codec issue!!!
Codecs
wingVTA is offline   QUOTE Thanks
AMD (ATI) GPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
