Hello!
After I overclock from 3.3 to 3.4, changing voltage up a notch or keeping current, my PC will restart Itself after saving saving setting In BIOS (right after windows logo), and If I power down and start up, It does the same over and over. No BSOD, no nothing.
Please note I disabled 2 out of the 6 cores, for some reason have found more stability that way (even though temps were never an Issue). This has kind of confused me.
Specs:
AMD Phenom II X6 1045T
EVGA GTX 660 SC
Gigabyte GA-78LMT-S2p
RAIDMAX RX-600AF-B 600W
8GB Dual Channel DDR3 RAM (Multiplier lowered to match stock speeds during overclocked due to locked CPU)
Hyper 212 EVO - ArticSilver 5
Don't laugh, It's my first PC build Graphics card and power supply are brand new.
Current clock tested via Prime95 for 9 hours (please don't make this an argument about load test times ).
I'm new to overclocking, and the problems that arise during overclocking, so any help would be much appreciated. I have searched the Issue, but have not found much on It. Trying to squeeze as much out of this as I can until I can upgrade.
If you need me to post more just say so! Thanks for any help that Is given.
Idle Temp - 32C
Prime95 (Highest recorded temp) - 52C
CPUZ-
Stable BIOS Settings-
Specs:
EVGA GTX 660 SC
Idle Temp - 32C
CPUZ-
