I am currently building a new system and for what ever reason my AX760I wont power it up to the point of hitting the BIOS. All that happens is the fans turn on, the various mother board lights flash and a clicking comes from the power supply. I have tried in the case, outside the case, one stick of ram, the other stick of ram, disconnecting all but the two power cables etc. Now strangely I can take it and plug it into my old setup and it works perfectly. Been powering it for a couple days without skipping a beat even while running hard. On top of that the cheap Dynex power supply from my old setup works just fine with the new one. I really don't want to leave things the way they are. The 450w Dynex just doesn't have enough power for what I plan to install in my new setup and running a 8 year old pc on a 200 dollar power supply is a bit of a waste. Any assistance would be greatly appreciated.
Here are the specs on both systems
New(Currently running off of 450 Dynex)
Case - Corsair 600T
Motherboard - MSI A88X-G45
CPU - AMD A10-7850K
RAM - Corsair Dominator Platinum 8GB (4x2) DDR3 2400
HDD1 - Corsair Neutron Series GTX 120GB
Disc Drive - Plextor PX-891SAW
Fans - 2x120mm, 2x200mm
CPU Cooler - Corsair H80I
Old(Currently running off of Corsair AX760I)
Case - NZXT Nemesis Elite
Motherboard - MSI K8N Neo 4 Platinum
CPU - AMD FX-57
RAM - Corsair 2GB DDR 400
HDD1 - WD 650GB Black
HDD2 - WD 650GB Black
GPU - Diamond Radeon HD 3870 oc edition
Fans - 3x120mm
Case - Corsair 600T
CPU - AMD A10-7850K
CPU - AMD FX-57
Fans - 3x120mm
