Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
READ READ There are much better stuff for heatsinks than copper!!
Thread Tools
Old 09-12-02, 10:50 PM Thread Starter   #1
dxiw
Disabled
dxiw's Avatar
I was just wondering for all you true DIY ppl out there try making a waterblock out of graphite heres why.
here is chart of all the thermal conductivities:
http://hypertextbook.com/physics/the...on/index.shtml
aluminum is 237
copper is 401 (hence better cooler)
silver is 429
diamond is 895!
but whats insanely awesome is
graphite (parallel) at 1950..the only problem is its a non-metal....
it is hard though...
I think it would make an awesome awesome water block if the water cool cool that graphite fast enough...it would never work in a ir cause no fan coud cool a heatsink thats pulls away heat so fast....
what do you guys think about this though?
dxiw is offline   QUOTE Thanks
Old 09-12-02, 11:03 PM   #2
Lusankya
Lusankya's Avatar
someone pull apart a disk break or drum break and get the shoes and try those :P
__________________
Asus G1Sn-B1 7/18/2008- ??
Intel Core 2 Duo Penryn T9300 2.5GHz 6MB 800FSB/4GB DDR2/nVidia GeForce 9500M GS 512MB/15.4” WSXGA+ 1680X1050 (Wet)/320GB/Blue-Ray Disk/DVD-RW
Deceased:Sager NP9860 11/24/2004 - 7/9/2008.. R.I.P
Intel 3.4GHZ P4 LGA775, 800FSB/3GB 533DDR2/256MB PCI-Express NVIDIA GeForce GO 6800/60GB/17" WSXGA+ 1680 X 1050/8X DL DVD-R
Lusankya is offline   QUOTE Thanks
Old 09-12-02, 11:07 PM   #3
Diggrr
Underwater Senior Member
Diggrr's Avatar
10 Year Badge
Yeah, but isn't parallel graphite non-waterproof?, almost a felt like material? Adding the binding resin will kill the conductivity numbers.
One more problem, alot of heat conductivity tests were based on electrical conductivity...I doubt most charts I come across since the CuSil debacle.
There is poco foam, a graphite foam with killer surface area. Alas, it too isn't waterproof.
If you find out more about this stuff, pass it on!
__________________
Rig1: C2D E8400 @3510 Ф Asus P5G41T-M-LX Plus mobo Ф 8 Gigs Ballistix DDR3 1333 Ф Asus GT520 Silent Ф 4 Deep Cool 92mm case fans Ф FSP 1U 460 Watt PSU
External Watercooling: QP-320-Res w/Gentle Typhoon's and metal screen filters Ф Cooling modded MCP350 & MCP355 W/Swiftech white dual pump top Ф D-Tek Fuzion V2 Ф 1/4" Norprene tubing
Life's Tragedy is that we get old too soon and wise too late. ~ Benjamin Franklin
Diggrr is offline   QUOTE Thanks
Old 09-12-02, 11:17 PM   #4
Since87
Re: READ READ There are much better stuff for heatsinks than copper!!
However:
graphite (perpendicular) 5.7
I suspect it is not easy to find a large chunk of graphite with the crystalline structure oriented in the same direction throughout the chunk. I don't think it all that hard either. Pencil leads are made of graphite combined with clay to make them harder. I'd guess your waterblock might get eroded away by water flowing through it. And they say higher flow is always better
Me personally, I'd settle for a diamond big enough to build a waterblock out of.
Since87 is offline   QUOTE Thanks
Old 09-12-02, 11:18 PM   #5
Jkasmann
Graphite is an anisotropic form of copper, meaning its properties vary directionally. Note that in the parallel direction graphite is a great thermal conductor, and in the perp. direction it is basically an insulator. The same is true for hardness, in one direction it can withstand high stress but in the other very little shear force.
I am not sure, but I think the strength and conductivity directions are different (check me someone). In other words, if that is true, the direction of high stress strength is a thermal insulator.
Diamond is the isotropic form of carbon (same properties in all directions) which is why it is both hard and thermally conductive regardless of orientation.
Jkasmann is offline   QUOTE Thanks
Old 09-13-02, 12:06 AM   #6
SkiFletch
SkiFletch's Avatar
how about industrial grade diamonds?
SkiFletch is offline   QUOTE Thanks
Old 09-13-02, 12:16 AM   #7
Skulemate
Skulemate's Avatar
Quote:
Graphite is a form of carbon.
Skulemate is offline   QUOTE Thanks
Old 09-13-02, 01:26 AM   #8
grunjee
grunjee's Avatar
Hmmm. I was hoping to gain some enlightenment in this thread, but instead have decided to stick with my Maze2.
grunjee is offline   QUOTE Thanks
Old 09-13-02, 02:04 AM   #9
AZZKICKER
Senior Member
AZZKICKER's Avatar
10 Year Badge
i dont understand why we dont see nickel plated stuff
nickel is one awsome heat releacer and or absorber
should be sinks of copper coated with nickel
think what a SK800 would do if it was nickel plated
__________________
" The Air Cooling Master "
AZZKICKER is offline   QUOTE Thanks
Old 09-13-02, 02:47 AM   #10
Seal
Seal's Avatar
i got a better idea guys, someone just build one out of a huge diamond. or how about helium 2? ~100,000 it says on teh site lol.
Seal is offline   QUOTE Thanks
Old 09-13-02, 09:22 AM   #11
The Overclocker
er...
we do, i cant think of any examles here (i think there ware some ram sinks) but it works on the same idea as silver or tin plating - it is mearly to fill in the gaps on the base then help thermal conductivity.
The Overclocker is offline   QUOTE Thanks
Old 09-13-02, 09:57 AM   #12
glass
didn't some heatsink manufacturer have a early tech. sample of graphite hs sometime during last spring.. i remember seeing some stuff of it. too busy to search the archives..
glass is offline   QUOTE Thanks
Old 09-13-02, 10:05 AM   #13
Maximouse
Maximouse's Avatar
Quote:
Get yourself a Diamond studded AX7
They probably sell them in some computer shop in Beverly Hills
Maximouse is offline   QUOTE Thanks
Old 09-13-02, 11:11 AM   #14
CrashOveride
CrashOveride's Avatar
it woudl be sweet to jsut have a diamon in side your wb that onyl thouches the core adn then goes in the the water compartment, but i dont think that the water coudl get ath much from it...
__________________
.................................................. ......................Just too busy with life
...........................................Team.32.Mentor........................................RED.BELT.Ubercloxx0r
..............................You.should.always.keep.an.open.mind.help.can.be.found.in.the.most.unlikly.places.
.....AIUHB0252@2300mhz.SP-97~Abit.NF7-S~512.RAM@fast.timings~9700Pro.w/.copper.HSF.~.2.monitors
.................................................. ..Windows XP because I have conditions
....Fold.for.[OC]FoldingNinjas!!!....You .would.be.amazed.at.what.a.group.of.intelegent.peo ple.can.overlook
...............................................All.blanket.statments.are.false|Nothing.is.absoloute.
............................Don't.Let.ThermalTake.Your.Money~|~Are.You.Into.Th at.Hacky.Stuff?
AKA:supaiku
.................................................. ........Can.you.find.the.ninja.in.my.avatar?!?!
CrashOveride is offline   QUOTE Thanks
Old 09-13-02, 11:48 AM   #15
Silversinksam
Moderator/ Silver Paste Taster©
Silversinksam's Avatar
10 Year Badge
I think you got confused, Nickel and Tin are terrible thermal conduits. Besides plating is useless, even if its Silver plated. For heatsinks that have poorly soldered fins to the base, Silver plating can help a great deal as it makes a better bonding to the fins and the base.
Thermal Properties of Materials
Thermal Conductivity, W/cm-K
Metals
Aluminum 2.165
Beryllium 1.772
Beryllium-copper 1.063
Brass 70% copper, 30% zinc 1.220
Copper 3.937
Gold 2.913
Iron .669
Lead .343
Magnesium 1.575
Molybdenum 1.299
Monel .197
Nickel .906
Platinum .734
Silver 4.173
Stainless Steel-321 .146
Stainless Steel-410 .240
Steel, low carbon .669
Tin .630
Titanium .157
Tungsten 1.969
Zinc 1.024
__________________
-15 May 2012: On Hiatus helping bees and the planet at the moment
-You have over 101 posts and Can't see the classifieds??? Click this link.
My Heatware
Silversinksam is offline   QUOTE Thanks
Old 09-13-02, 12:20 PM   #16
6502kid
6502kid's Avatar
Does anybody make a solid silver HS ?
6502kid is offline   QUOTE Thanks
Old 09-13-02, 01:12 PM   #17
JaY_III
Senior of BX
JaY_III's Avatar
10 Year Badge
Quote:
I have seen a solid silver waterclock, was a sprial block....
but its not worth the money for the little gain over copper, and a big hole in your pocket book.
JaY_III is offline   QUOTE Thanks
Old 09-13-02, 03:25 PM   #18
grunjee
grunjee's Avatar
Back in the day I got a NoiseControl Silverado afer Tom declared it the king of HSF's in 3 straight shootouts (I think it was 3) ... this was when I had a P3/866 which at the time was among the better chips you could buy.
Anyway the thing's base had a chunk of solid silver that weighed... I want to say 500g, don't hold me to that, but it was massive.
It was a great HSF then but I doubt it could do much for today's AMD chips.
Old 09-13-02, 04:05 PM   #19
CrashOveride
i actualyl belivce silversinkssam has made soem or mad e silver hybrid sink, or was that some1 else sam?
__________________
AKA:supaiku
Old 09-13-02, 04:17 PM   #20
Nico3k
Nico3k's Avatar
interesting...
i wonder how good a glass waterblock would be
Nico3k is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
