Notices
Overclockers Forums > Hardware > Display and Sound Technology > Sound Systems & Audio Devices
Sound Systems & Audio Devices Including sound cards, speakers and other audio devices.
Forum Jump
Headphones with Headaches...
Thread Tools
Old 09-10-04, 07:55 PM Thread Starter   #1
Hypnos
Hypnos's Avatar
Question Headphones with Headaches...
I have some labtec elite 835's but they aren't great and they give me headaches. My meds control most of my headaches but the pressure from some headphones makes them worse. So I am looking to find some good, but low pressure headphones, Any ideas what would fit the bill for ~100$?
Hypnos is offline   QUOTE Thanks
Old 09-11-04, 12:04 AM   #2
SniperXX
SniperXX's Avatar
Your sure its the pressure and not the bass right? Sorry I am just asking cuz I will get a headache with a pair of my closed ear headphones, it was cuz of the bass, at 1st I had thought pressure.
Isnt $100 alot for headphones? They got some nice ones cheaper.
__________________
i7 920 @ 4.2Ghz
Asus Rampage II GENE
2x BFG GTX285
6GB Crucial Dominator 1600
Crucial 750TX
Help find cures for cancer by running Folding @ Home.
HEATWARE
SniperXX is offline   QUOTE Thanks
Old 09-11-04, 03:39 AM Thread Starter   #3
Hypnos
Hypnos's Avatar
Quote:
It isnt the bass, unfortunately, I am one of the lucky ones who gets bad migrane headaches, like put you into the hospital bad. I like loud music sometimes, but the tension of the headphones, more than bass or volume is the worst part, I can always turn it down.
Being headache free has no price in my book
Old 09-11-04, 06:42 AM   #4
breez
I'm using Sennheiser HD555 and I find them very comfortable The velour pads go around your ears. They also sound quite smooth, lacking the shrill/harsh highs of my previous headphones Philips HP800 (that Philips was in a different priceclass though).
breez is offline   QUOTE Thanks
Old 09-11-04, 02:09 PM   #5
Ryan T
I Have the Sennheiser HD-580's and the HD-580/600's are the most comfortable headphones IMO. You can usually find a pair of 580's used for around $120 or so.
Ryan
Ryan T is offline   QUOTE Thanks
Old 09-11-04, 02:42 PM Thread Starter   #6
Hypnos
Hypnos's Avatar
I have found the HD 570's on Newegg for 129, and after having a name to drop, I got to try a pair out...Man are they nice, Thanks for all your help guys!
Old 09-11-04, 03:58 PM   #7
breez
http://froogle.google.com/froogle?q=...ogle&scoring=p
You can have those for much less... In Germany those sell for ~60
Old 09-13-04, 04:26 PM Thread Starter   #8
Hypnos
Hypnos's Avatar
Froogle Huh? Haven't used this before...Thanks Breez
Old 09-13-04, 04:30 PM   #9
stryder2720
stryder2720's Avatar
My headaches are caused by the headphones pushing on the sides of my head cutting off blood flow or something. Get some Bose Triports or Quietcomfort headhones and all the headaches will go away. But Im sure I will get flamed for saying Bose here but I love my Quiet Comfort 2s cause they are SOOOOO comfortable. Before I had Senn. 212pros.
stryder2720 is offline   QUOTE Thanks
Old 09-14-04, 12:00 AM   #10
secretweapon
secretweapon's Avatar
Are u a gamer at all? If you are a gamer I recommend Sennheiser PC150/155s. Great earphones with a noise canceling mike. If you're not then try Sennheiser HD range or Bose Triports.
secretweapon is offline   QUOTE Thanks
Old 09-19-04, 11:39 PM Thread Starter   #11
Hypnos
Hypnos's Avatar
Yes I game with them, but I want to use them with my mp3 player as well. Any good headphones with a detatchable mic maybe? Haven't really seen anything like that out there.
Old 09-20-04, 06:13 PM   #12
Critical Bill
Critical Bill's Avatar
Quote:
Yeah, that would be VERY cool if you could get a great set of headphones w/ a detachable mic.
Critical Bill is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
