Notices
Overclockers Forums > Hardware > Video Cards > nVidia GPUs
nVidia GPUs
Forum Jump
6800 GT -> 6800 Ultra Extreme
Thread Tools
Old 08-18-04, 11:34 PM Thread Starter   #1
nissmo300
nissmo300's Avatar
I saw someone post this on another board:
Quote:
I flashed the bios of my 6800 GT to the EVGA 6800 ultra extreme just now. I'm cooling the thing with my Koolance EXOS. The flashing process was flawless. The computer registers it as an ultra but it has the ultra extreme clocks.
I just ran 3dmark 2003 and I got 12,757 points... which i assume is good. I'm gonna try it again when i put my CPU at 3.6 GHz rather than 3. If you have a solid cooling for your 6800 GT i definitely suggest flashing it's bios to the ultra extreme... i didn't notice any artifacts or anything it wasn't even difficult. I got the bios files here: http://www.mvktech.net/download.php
UPDATE: Stock clocks of the:
6800 GT - 350 mhz/core 1000 mhz/mem
6800 Ultra - 400 mhz/core 1100 mhz/mem
6800 Ultra OC - 425 mhz/core 1100 mhz/mem
6800 Ultra Extreme - 450 mhz/core 1200 mhz/mem
If you can get the 6800 GT to clock to the speed of an Ultra, how much can you OC a Ultra or an Ultra Extreme for that matter?
nissmo300 is offline   QUOTE Thanks
Old 08-18-04, 11:42 PM   #2
Avg
Senior Member
Avg's Avatar
6800 gt 350mhz/core 1.0ghz/mem
6800 Ultra 400mhz/core 1.1ghz/mem
6800 Ultra Extreme 450mhz/core 1.2ghz/mem (clocks may vary)
http://www.hothardware.com/viewartic...?articleid=568
Quote:
__________________
Avg is offline   QUOTE Thanks
Old 08-18-04, 11:49 PM Thread Starter   #3
nissmo300
nissmo300's Avatar
Thanks AVG, thats helpful. Now we need to find some people who own any of these and see how far they can OC them.
Old 08-19-04, 12:21 AM   #4
myzhi
How high were you able to o/c the before flashing to Ultra extreme?
myzhi is offline   QUOTE Thanks
Old 08-19-04, 12:22 AM Thread Starter   #5
nissmo300
nissmo300's Avatar
It's not mine, I said I found this post in another forum. Has anyone tried flash their 6800 GT with the bios of a 6800 Ultra Extreme?
Old 08-19-04, 01:16 AM   #6
Myhre
Myhre's Avatar
My PNY maxes out around 430/1.25 but that's without any flashes. I'm getting around 13k on 3dmark03. I don't think I want to flash up, I don't really think it gives that much of a perf boost, versus what it could do to the card. There is overclocking and then there is reckless abandon. I don't want to end up with a paperweight.
Myhre is offline   QUOTE Thanks
Old 08-19-04, 01:22 AM Thread Starter   #7
nissmo300
nissmo300's Avatar
That's very close to a Ultra Extreme. Good job. How do you think the BFG series overclocks?
EDIT: By the way what is the temp on it?
Old 08-19-04, 02:25 AM   #8
Pitbull2k
my PNY goes up to 440/1110 on stock
And it dosent get too hot over 75 i think.
Pitbull2k is offline   QUOTE Thanks
Old 08-19-04, 07:38 AM   #9
Myhre
Myhre's Avatar
It idles around 59C and never goes over 75C from what I can tell.
Old 08-19-04, 08:38 AM   #10
Nandro
Disabled
Nandro's Avatar
My BFG GT will only go up to 426/1.07 water cooled at 40C. I may have just got a poor overclocker although i am happy with its performance. I have been able to go up a bit at a time with riva tuner, maybe the AS5 needs to cure a bit. I would highly recommend testing before doing this.
Nandro is offline   QUOTE Thanks
Old 08-19-04, 09:21 AM   #11
Myhre
Myhre's Avatar
Quote:
Which BFG do you have? The one with the reference heatsink or the one with the Double fan chrome one?
Old 08-19-04, 09:32 AM   #12
Nandro
Disabled
Nandro's Avatar
I have the reference design.
Old 08-19-04, 09:53 AM Thread Starter   #13
nissmo300
nissmo300's Avatar
Does anyone have a picture of the reference design?
Old 08-19-04, 10:20 AM   #14
bobmanfoo
Disabled
i have the reference BFG GT as well, modded my GT bios to give 1.4v and set clocks to 425/1.12, i am now able to max out at 450/1.18, custom cooled
hey Nandro, what water block are you using?
bobmanfoo is offline   QUOTE Thanks
Old 08-19-04, 11:04 AM   #15
mms4ba
mms4ba's Avatar
How safe/unsafe is flashing your vid bios?
Can you flash back to the original bios if you choose?
mms4ba is offline   QUOTE Thanks
Old 08-19-04, 11:06 AM   #16
Avg
Senior Member
Avg's Avatar
You can flash back to the original bios, but you'll need an pci video card to boot from, but sometimes that's not possible and you'll end up with a really expensive paperweight.
__________________
Old 08-19-04, 07:22 PM   #17
Silver
Senior Citizen (aka old fart)
Silver's Avatar
I like testing with vgabios.exe prior to actually flashing. At least I am relatively assured of being able to flash back.
__________________
Xeons 1.6LV at 3.2Ghz
3000+ (754) at 2.5Ghz
2800+ (754) at 2.5Ghz
P4 2.8C-478 at 3.4Ghz
Celeron 315D at 3.4Ghz
Celeron 310D at 3.0Ghz
Celeron 335D at 3.7Ghz
Celeron 315D at 2.8Ghz
C2D E6300 at 3.2Ghz
C2D E6300 at 3.0Ghz
FOLDING FOR TEAM 32 - 30.7 Ghz
Avatar by Shocker - Many Thanks Sir!
Silver is offline   QUOTE Thanks
nVidia GPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
