- May 10, 2009
(Please note this is a work in progress and may change somewhat, don't let this discourage you! Anything you submit will stay listed, it may just move slightly)
This thread is for all to submit their SuperPi 1M Scores for a Categorized Top List. Scores for a Categorized Top List. All OCForum members have a chance to be listed here! This is not exclusive to OCF Benching team people. While this is a nice and friendly intraforum competition thread, this thread is also useful as a reference for what your score should and can achieve with this benchmark.
If you are unfamiliar with SuperPi 1m, please click here and read this page.
To download the proper version of SuperPi, click here.
PLEASE READ THESE INSTRUCTIONS BEFORE POSTING!
1) You must use this version of superpi: Link
2) Run the 1M test.
3) Take a screenshot of the finished superPi run and CPUz memory and main tabs.
Your screenshot should look like this:
4) Post the screenshot in this thread, either as an attachment or hosted elsewhere.
5) Alternatively, a link to a HWBot submission works fine too.
6) Done!
The following format is preferred, but not necessary:
[*B]USER[/b] - [*URL="http://link-to-screenshot-or-HWBot-score-goes-here"]SCORE[*/URL] - CPU @ CPU SPEED - MEMORY SPEED/TIMINGS, COOLING (AIR,H2O, DRY ICE, LN2, ETC.)
Examples [*B]Bobnova[/b] - [*URL="http://hwbot.org/community/submission/1023292_bobnova_superpi_core_i3_540_7sec_347ms"]7.347[*/URL] - i3 540 @ 5785Mhz - DDR3@754mhz 7-7-7-18. (Dry Ice)
[*b]Bobnova[/b] - [*URL="http://bobnova.com/ocforums/pi15.125.JPG"]15.125[*/URL] - e6300 @ 3719Mhz - DDR2@531-5-5-5-12 (Dry Ice)
You can copy either example and paste your info in it!
(Leave asterisks in place until I have your score posted, then edit your post if you want to.)
You may also leave the link at it's default and attach your screenshot to your post.
NOTE: This may delay my getting to your score, especially if a lot of people do this.
If you would like to see the scores of the benchmarking team, you can see those HERE (Thanks Voidn!!!). A lot of these guys run extreme cooling and have a lot of tricks and tweaks up their sleeves to reach those scores. If you are interested in joining the benchmarking team and raising your scores, please CLICK ME. In here once you completed your 10 benchmarks and joined OCF at Hwbot, you will gain access to the benching lounge and get to share and learn some of the secrets of our team! You will not find a better group of guys to learn and share tricks and tweaks with!
Overall Top Guns AMD (regardless of CPU type, best score per person)::
Overall Top Guns Intel (regardless of CPU type, one score per person):
AMD:
Phenom II:
Athlon II/Sempron Sargas:
1.xsuperbgx - 16.743 -AMD sempron 140 @ 5313Mhz - DDR2@394mhz 4-3-3-9. (LN2)
2.bda1967 - 21.263 - Athlon II X4 635 @ 3711Mhz - DDR3-1600@683MHz 7-7-7-20 (AIR)
Phenom:
1.
Athlon64/Sempron (AM2/AM2+):
1.cold.nut - 22.625 - Athlon 64 6000+ X2 @ 3840MHz - DDR2-426MHz @ 4-4-4-7-17 2T (dry ice)
Socket 939:
1.miahallen - 30.791 - Athlon64@2910mhz - DDR-265@3-4-4-8-16-1T. (water)
3.Kowalski3500 - 35.359 - Opteron 165 @ 2457 - 223/3-4-4-8, Air
Intel
Sandy Bridge (lga1155):
Core i7 (X58-1366):
Core i7 and i5 Quads (P55/H55-1156):
1.miahallen - 7.920s - i5 750 @ 5187Mhz - DDR3@1976 6-7-6-18 1T (LN2)
2.SamSaveMax - 8.548 - i5 750 @ 4868.3Mhz - DDR3@811mhz 8-9-8-24 1T (AIR)
3.Earthdog - 8.751 - i7 860 @ 4.880Mhz - DDR3 960Mhz / 9-9-9-24, ( DRY ICE)
4.Brutal-Force - 8.766 - i7 860 @ 4.771GHz - 1054 MHz (DDR3)/8-8-8-24-2, (AIR)
5.redduc900 - 10.055 - i7-860 @ 4160Mhz - DDR3@1248 9-11-9-28-1T (Air)
6.Sinj - 10.461s - i5 760 @ 4.00GHz - 765 MHz (DDR3)/9-9-9-27-1, (AIR)
Core i5 (dual core):
1.miahallen - 6.500s - i5 670 @ 6553Mhz - DDR3@1402 6-6-6-18 1T (LN2)
2.dejo - 7.223 - I5 670 @ 5880 - 9-DDR3-1050/9-9-9-24, COOLING - Dry Ice
3.jaymz9350 - 8.203 - i5 655k @ 5225.8Mhz - [email protected] 9-9-9-24. (Air)
4.SamSaveMax - 8.390 - i5 650 @ 5026Mhz - DDR3-1005@9-10-10-28 (Air)
5.Jmtyra - 10.546 - i5 655k @ 4019 Mhz - 837.4 MHz (4:20) @ 9-9-9-24, Air-ish (H50)
6.Super_Nade - 13.382 - i5 430m(ish) @ 3511Mhz - DDR3@702mhz 7-7-7-20. (AIR)
Core i3:
1.Bobnova - 7.347 - i3 540 @ 5785Mhz - DDR3@754mhz 7-7-7-18. (Dry Ice)
2.87dtna - 7.677 - i3 540@ 5635Mhz - DDR3@980mhz 10-9-9-27. (Dry Ice)
3.SamSaveMax - 8.109 - i3 540 @ 5199Mhz - DDR3-902MHz @ 9-10-9-27 1T (AIR)
4.Woomack - 8.312 - i3 540 @ 5199MHz - DDR3 904/ 9-8-8-24 1T, ( H2O )
5.Georanma - 9.859 - i3 530 @ 4.3674 595MHz/6-6-6-15, Air
Core2 (45nm):
1.Hilight8.109 - E8600 @ 5608Mhz - DDR2@560 5-5-5 (SS)
2.Woomack - 8.297 - E8500 @ 5734MHz - DDR2 604Mhz / 5-5-5-15 1T, ( LN2 )
3.SamSaveMax - 9.532 - E8500 @ 4905.2Mhz - DDR2-545@5-5-5-15 (Air)
4.Lucky23 - 11.109s - e8500@4227mhz - DDR2@445 5-4-4-12 (AIR)
5.Badbonji - 14.976 - P9500 @ 3.13GHz - 494.8MHz / 5-5-5-15, (Stock)
Other 45nm (45nm e6xxx, e5xxx, e3xxx):
1.sidewalkcookie - 16.047 - e5400@3605mhz - DDR2@534 6-6-6-18 (Stock AIR)
Core2 (65nm):
1.xXSebaSXx - 14.531 - E6300 @ 3920Mhz - DDR2@560mhz 5-5-5-15-42-1T (DICE)
2.wilddeuces 14.682 - QX6700 @ 3600Mhz - DDR2@360Mhz 5-5-5-15 2T, AIR
3. Bobnova - 15.125 - e6300 @ 3719Mhz - DDR2@531-5-5-5-12 (Dry Ice)
65nm other (65nm, e4xxx, e2xxx, e1xxx, NOT P4 based!):
1.
P4 based CPUs:
1.
2) Run the 1M test.
6) Done!
- I.M.O.G. - 10.453 - 965BE @ 6576 - Gskill Trident @ 786/7-7-7-15, (LN2)
- xsuperbgx10.813 - AMD 955BE @ 6460.2Mhz - DDR3@876mhz 7-7-6-15-20-1T (LN2)
- miahallen - 11.015s - X6 1090T @ 6412Mhz - DDR3@950 9-9-9-24 1T (LN2)
- 87dtna - 11.938 - 955BE @ 5858mhz - Corsair @ 673/5-5-5-15, (LN2)
- ChanceCoats123 - 12.281 - Phenom II 555 @ 5607 - DDR3 712 @ 6-7-6-20-24-1T, DIce
- Dolk - 12.750 - Phenom II 1090T @ 5,563 - 1685 8-8-8-24-30, DRY ICE
- xsuperbgx - 13.463 - Phenom II X4 955BE @ 5288Mhz - DDR3@750mhz 9-9-9-24. (Dry Ice)
- 87dtna - 13.978 - Phenom II 555be@ 5033mhz- DDR3@800-8-8-8-24 (Dry Ice)
- xXSebaSXx - 14.180 - AMD 720BE (3 Cores Active) @ 4875 - 833/7-8-7, DICE
- xokeman - 14.234 - Phenom II 965 BE@5100 - DDr3@667/7-7-7-24-33, (DRY ICE)
- Old H-Ware Tech - 15.078 AMD 955 @ 4510.5Mhz DDR3 @ 820.1Mhz CL9-9-9-24 1T H70 H20
- Hilight15.086 - X6 1090T @ 4575Mhz - DDR3@915 6-9-6-24 1T (Air
- Dooms101 - 15.313 - PhII 965BE 4.558Ghz - DDR3-1413Mhz (7-8-8-25) - Air
- Pvt.Dancer - 15.450 - Phenom II 1090t@ 4477mhz DDR3@682mhz 8-8-8-24 (AIR)
- wint0nic - 15.719 AMD 955 @ 4510.5Mhz DDR3 @ 820.1Mhz CL9-9-9-24 1T H70 H20
- saint19 - 15s 770ms - X6 1090T @ 4429.10Mhz - DDR3@1600-8-8-8-21 (Air)
- Prunecandy - 16.00 - phenom II 550 @4107ghz-ddr3@707mhz 8-8-8-23(air)
- Efonzerellie - 16.285 955BE @ 4275Mhz- [email protected] 8-9-8-25(Air)
- CgS Drone - 16.610 - 955BE @ 4199Mhz - DDR3@659mhz 9-9-9-28. (Air)
- Old H-Ware Tech - 17.203 - AMD 955BE @ 4098.6 - [email protected] 9-9-9-24, STOCK AIR
- wanner - 18.002 - Phenom II X4 955BE @ 3850Mhz - [email protected] 7-8-7-20. (Air)
- reddeathdrinker - 18.782 - Phenom X6 1055T @ 3808MHz - 725.3MHz/9.0-9-9 24, Air cooled.
- cold.nut - 22.625 - Athlon 64 6000+ X2 @ 3840MHz - DDR2-426MHz @ 4-4-4-7-17 2T (dry ice)
- QuietIce - 30.719 - Athlon64@2910mhz - DDR-265@3-4-4-8-16-1T. (water)
- Kowalski3500 - 35.359 - Opteron 165 @ 2457 - 223/3-4-4-8, Air
- nzaneb - 6.458 - i7 2600K @ 5769.1 mhz - HyperX @ 961.5/8-8-8-24, COOLING (H2O)
- miahallen - 6.500s - i5 670 @ 6553Mhz - DDR3@1402 6-6-6-18 1T (LN2)
- PolRoger - 6.692 - i5 2500K @ 5616.8MHz - Gskill Trident DDR3 @ 1070.3MHz/9-9-9-24 1T, (Air)
- Brolloks - 6.750 - i7 2600k @ 5502Mhz - DDR3@933mhz 7-7-7-18 1T (AIR)
- hokiealumnus - 6.771 - i7 2600k @ 5518Mhz - DDR3@1070mhz 9-11-9-28 1T (Water)
- discman - 6.817 - i5 2500k @ 5521.6Mhz - [email protected] 6-8-6-22 1T (Air)
- PolRoger - 6.833 - i7 2500K @ 5504mhz DDR3@ 800-6-8-6-24 (AIR)
- Discman - 6.930 - i5 2500k @ 5413.9Mhz - DDR3@936mhz 6-9-6-22 1T (Air)
- Voidn - 6.984 - 2600k @ 5295 - DDR3 933 @ 7-7-7-24, Air
- PhysX - 7.004 - Core i7 2600k @ 5356Mhz - DDR3@808Mhz - 9-9-9-24-1 (Air)
- Killahurtz - 7.301 - 2600K @ 5100Mhz - Dominator GT@1600-7-7-7-20 (H2O)
- DaveHCYJ - 7.192 - i5 2500K @ 5227Mhz - DDR3@804mhz 7-8-7-24. (Air)
- 87dtna - 7.213 - i5 2500k @ 5009Mhz - DDR3@800mhz 8-8-8-24 (Air)
- dejo - 7.223 - I5 670 @ 5880 - 9-DDR3-1050mhz/9-9-9-24, COOLING - Dry Ice
- A-Dub - 7.285s - 2500k @ 5188 - DDR3 @667/7-7-7-21 1T, H2O
- Bobnova - 7.347 - i3 540 @ 5785Mhz - DDR3@754mhz 7-7-7-18. (Dry Ice)
- ChanceCoats123 - 7.594s - Core i7 920 @ 5326MHz - DDR3@1015: 8-8-8-23-60-2T (Dry Ice)
- Earthdog - 7.941 - i7 920 @ 5166Mhz - DDR3@984mhz 8-8-8-24. (LN2)
- Hilight8.109 - E8600 @ 5608Mhz - DDR2@560 5-5-5 (SS)
- SamSaveMax - 8.109 - i3 540 @ 5199Mhz - DDR3-902MHz @ 9-10-9-27 1T (AIR)
- jaymz9350 - 8.203 - i5 655k @ 5225.8Mhz - [email protected] 9-9-9-24. (Air)
- spiritedandy - 8.268 - i7 980X@ 5019MHz / 7-7-7-20 1T (H70 corsair)
- Woomack - 8.297 - E8500 @ 5734MHz - DDR2 604Mhz / 5-5-5-15 1T, ( LN2 )
- xoke - 8.378 - i7 920 @4893ghz - DDr3 932mhz 7-9-7-24-102-1t (DRY ICE)
- onefstsnake8.520i7 920 d0 @ 4802.8 DDR3 @ 915 7-8-7 24 1T (Dice)
- lolwut - 8.674 - i7 920 @ 4777mhz DDR3@ 910-8-9-8-24 (H20)
- TomPC3 - 8.720 - i7 980x @ 4816 - 849mhz/6,8,6,24 1T, AIR
- Brutal-Force - 8.766 - i7 860 @ 4.771GHz - 1054 MHz (DDR3)/8-8-8-24-2, (AIR)
- Janus67 - 8.954 - i7 920 @ 4557mhz - G.Skill 840/9-9-9-24, Air
- Tokae - 8.980s - 980x @ 4610.8 - DDR3 @1600/8-8-8-24 1T, Air
- spiritedandy - 9.345s - i7 920 @ 4405Mhz DDR3@839 7-8-7-20 (Air)
- flaughert - 9.485 - i7 920 @ 4299.9Mhz - DDR3@819mhz 8-8-8-24. (air)
- bda1967 - 9.770 - i7 920 @ 4200Mhz - DDR3-1600@800MHz 9-9-9-24 (AIR)
- Noshei - 9.834 - i7 930 @ 4200Mhz - DDR3@800mhz 7-8-7-24. (H20)
- Georanma - 9.859 - i3 530 @ 4.3674 GHZ - 595MHz/6-6-6-15, Air
- DR650SE - 10.311 - 940XM@3929mhz - DDR3@701 9-9-9-21 (Stock AIR)
- Sinj - 10.461s - i5 760 @ 4.00GHz - 765 MHz (DDR3)/9-9-9-27-1, (AIR)
- redduc900 - 10.055 - i7-860 @4160Mhz - DDR3@1248 9-11-9-28-1T (Air)
- Jmtyra - 10.546 - i5 655k @ 4019 Mhz - 837.4 MHz (4:20) @ 9-9-9-24, Air-ish (H50)
- Lucky23 - 11.109s - e8500@4227mhz - DDR2@445 5-4-4-12 (AIR)
- arcanise - 12.333 - i7 960 @ 3339Mhz - DDR3@534 7-7-7-20 (AIR)
- xXSebaSXx - 14.531 - E6300 @ 3920Mhz - DDR2@560mhz 5-5-5-15-42-1T (DICE)
- Super_Nade - 13.382 - i5 430m(ish) @ 3511Mhz - DDR3@702mhz 7-7-7-20. (AIR)
- wilddeuces 14.682 - QX6700 @ 3600Mhz - DDR2-1000@720Mhz 5-5-5-15 2T, AIR
- Badbonji - 14.976 - P9500 @ 3.13GHz - 494.8MHz / 5-5-5-15, (Stock)
- sidewalkcookie - 16.047 - e5400@3605mhz - DDR2@534 6-6-6-18 (Stock AIR)
AMD:
Phenom II:
- ChanceCoats123 - 14.282 - Phenom II 720 @ 4860Mhz - DDR3@720mhz 6-6-6-20-24-1T. (Dry Ice)
- xXSebaSXx - 14.860 - AMD 955BE @ 4699.7 - DOM GTs 803MHz/7-8-7-21-24-1T, AIR
- Hilight15.086 - X6 1090T @ 4575Mhz - DDR3@915 6-9-6-24 1T (Air)
Phenom:
1.
Socket 939:
Intel
Core i7 (X58-1366):
- dejo - 7.556 - I7 920 @ 5355 -DDR3-1020mhz /9-9-9-24, COOLING Dry Ice
- nzaneb - 7.594 - i7 980X @ 5320Mhz - DDR3@931mhz 8-8-8-21. (Dry Ice
- xoke - 8.378 - i7 920 @ 4893ghz - DDr3 932mhz 7-9-7-24-102-1t (DRY ICE)
- SamSaveMax - 8.378 - i7 930 @ 4819.3Mhz - DDR3@918mhz 8-9-8-22 60-1T (AIR)
- Woomack - 8.674 - i7 920 @ 4678MHz - DDR3 891MHz / 7-6-6-19 1T, ( H2O )
Core i3:
Core2 (45nm):
Core2 (65nm):
1.
P4 based CPUs:
1.
