- Jun 25, 2004
Hey guys, I just wanna let everyone who might not already know, that VMware recently came out with a free version.
What VMware is, is a program that allows you to run a "Virtual Machine", or basicly an OS while your in your installed OS, a virutal OS.
For Beginners
The usefulness of this for Linux beginners is greater ability to experiment, and even better, stay in Windows if you need help or anything. The additional help is that you don't need to install the distro in case you don't want to yet, or are not too keen on it.
For Veterans
I'll add that VMware can be useful for linux Veterans because you can use this program on a Linux machine too, if you wanna test a new distro out or play around.
http://www.vmware.com/products/player/ -this is the site for the free VMware Player, there is also a Server version (not sure on it's uses).
***TAKE NOTE***
Thought everyone could benefit from this, since it's advantages are similar to that of a LiveCD, but with some great additional stuff too...and no I don't work for VMware or anything.
For Beginners
For Veterans
***TAKE NOTE***
Cited from http://fucoder.com/2005/10/install-gentoo-linux-vmware-windows-xp/site below said:You cannot use VMWare Player to create virtual machine images — VMWare requires you to get their Workstation or Server version to do that. It can be overcome by downloading an existing VM, and then re-install it with the OS of your choice. Or alternatively, use QEMU to create VM images in VMWare’s virtual disk file format.
