Notices
Overclockers Forums > Discussions > Forum Feedback
Forum Feedback Likes and Gripes about the Forums. No Post Count.
Forum Jump
Minimum Word Length in Search
Thread Tools
Old 10-28-02, 10:42 PM Thread Starter   #1
thef0x82
thef0x82's Avatar
Okay so what's up with this minimum word length in the forum search engine? It makes it almost impossible to search for some very useful things like:
AMD
any number < 1000
P4, P3
CPU
GPU
AGP
GNU
VIA
PCI
ISA
XP (for either the Athlon or the OS)
anyone else care to add any?
There are so many abbreviations, and we're apparently hosed by not being able to search for them.
Is there some way this can be fixed?
thef0x82 is offline   QUOTE Thanks
Old 10-28-02, 10:48 PM   #2
LutaWicasa
Immutable
Administrator
LutaWicasa's Avatar
10 Year Badge
Ya wanna find XP?
In the search, enter *XP*
Use the asterisk as kind of a "wildcard".
__________________
Abjure obfuscation
LutaWicasa is offline Heatware Profile   QUOTE Thanks
Old 10-29-02, 02:26 AM   #3
Oni
Oni-ni-Kanabō
Ninja Hippo eater Moderator
Oni's Avatar
10 Year Badge
That and many other things are also listed here:
http://forum.oc-forums.com/vb/showth...hreadid=122094
__________________
Mama, put my guns in the ground. I can't shoot them anymore.
On Indefinite Hiatus
Asus P6T SE
Intel i7 930 @ Stock
12GB Corsair DDR3 9-9-9-24
XFX Radeon 5830 @ Stock
Corsair 750 Watt PSU
Oni is offline   QUOTE Thanks
Old 10-29-02, 10:28 AM Thread Starter   #4
thef0x82
thef0x82's Avatar
Forgive my ignorance.
Old 10-29-02, 06:22 PM   #5
skip
OCForums Founder & Extraordinarily Elusive Administrator
skip's Avatar
10 Year Badge
For each Char we decrease the minimun, it ads about 500MB+ to the Database. Space is at a premium as we cannot afford any additional space.
As LutaWicasa said, Use * in your searches. Has the same result.
__________________
Born to be Wild!!
skip is offline   QUOTE Thanks
Old 10-30-02, 06:17 AM   #6
Superman53142
Superman53142's Avatar
And think of how long it would take you guys to redo the database entries, LOL. With so many posts on the boards it would probably take days.
Superman53142 is offline   QUOTE Thanks
Old 10-30-02, 07:02 AM Thread Starter   #7
thef0x82
thef0x82's Avatar
Off topic.... I like the avatar Superman.
Old 10-30-02, 11:33 AM Thread Starter   #8
thef0x82
thef0x82's Avatar
Okay I'm trying to do a search that has the number '2' in it. I've tried using 2***, *2**, **2*, and ***2. It won't work, it says that it doesn't meet the minimum lenght. Any suggestions?
Old 10-30-02, 02:36 PM   #9
Thelemac
Administratively Deficient
Thelemac's Avatar
10 Year Badge
I'm gonna say that you can only have one wildcard on either side. So...make it something else is about all I can suggest.
Incidentally, that would be a completely unhelpful search, since that would return every single post that had the number 2 in it, even if it weren't by itself (eg 20).
So, you'd get a HUGE number of hits, and wouldn't really narrow the amount of information down much.
__________________
42 | Sig Assassin
*click*
Thelemac is offline   QUOTE Thanks
Old 10-30-02, 10:25 PM Thread Starter   #10
thef0x82
thef0x82's Avatar
I was trying to find a thread that I know I've seen where someone was asking about having 2 NICs installed on their computer.
Old 10-31-02, 01:31 AM   #11
Thelemac
Thelemac's Avatar
10 Year Badge
So maybe search for 2 AND NIC?
Or better yet NIC...you'll get far fewer results with just NIC than with 2.
__________________
42 | Sig Assassin
*click*
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
