Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
One for the pro's. "Watercooling"
Thread Tools
Old 06-22-01, 07:50 PM Thread Starter   #1
swanie
Hi there
I wonder if any of you know what the C/W is for an alluminium waterblock?
Lets say my room temp is = 21c
my water temp is = 25c
my cpu temp is = 46c (according to mobo)
My Watt is = +/- 63
I'm running a t'bird 1000@ 133x9=1200@1.6v
swanie is offline   QUOTE Thanks
Old 06-22-01, 09:32 PM   #2
wildone
Senior Member
download radiate you can get it from the front page of oc.com ,I will get a link
Not sure about the answer off the top of my head but just wanted to say welcome to the forums
wildone
__________________
Windows is a 32-bit patch to a 16-bit GUI for an 8-bit operating system written for a 4-bit processor by a 2-bit company that can't stand 1-bit of competition!!!
Sometimes what happens to you in life makes life hard to live,sometimes what you do in life make it hard also,then sometimes they both combine to make it unbearable.
wildone is offline   QUOTE Thanks
Old 06-22-01, 09:39 PM   #3
wildone
Senior Member
Oh here is the link hope this helps
wildone
http://www.overclockers.com/articles430
__________________
Old 06-22-01, 09:50 PM   #4
AMDGuy
AMDGuy's Avatar
Quote:
swanie (Jun 22, 2001 08:05 p.m.):
Hi there
My Watt is = +/- 63
With the numbers you posted C/W is .39. I'm sure this is off as you posted "room temp" when "ambient temp" is needed for the equation. Ambient is usually measured 1" from the processor. The formulae is
Delta = CPU Temp - Ambient Temp
C/W = Delta/Watts
Hope this helps. Definitely download radiate!
__________________
-AMDGuy
Guess I need to change my username?
i5 750 @ 4.01Ghz (191 x 21 with EIST enabled)
1.32500 Vcore 1.15 Vtt
Gigabyte P55 UD3R
4GB OCZ Platinum 1333
AMDGuy is offline   QUOTE Thanks
Old 06-23-01, 06:31 PM Thread Starter   #5
swanie
THX Chaps
So all in all... the waterblock is not that good unless you use it with a peltier or by keeping the water temp as low as possible... say 15c.
I've seen HSF with a lot lower C/W....around .25 and .18
Hmmmm....wonder if lapping the block would bring the C/W down....
Any advice would be appreciated.
Old 06-24-01, 12:05 AM   #6
Thelemac
Administratively Deficient
Thelemac's Avatar
10 Year Badge
Well, that's not your actual C/W as you didn't really measure the temps right. You would have to measure them for ambient 1" from the top and for cpu stick a thermlecouple next to the die (good enough for this, though a reviewer should probably do it to AMD's specs).
This was mentioned above, but you apparently didn't pay attention. The temps you are using aren't really good enough to determine actual performance to the level you are looking for. They are good enough to decide if your cpu is going to die.
Lapping would help if it wasn't done at the factory and if there was some damage done to the bottom of the block (scratches or what have you)
__________________
42 | Sig Assassin
*click*
Thelemac is offline   QUOTE Thanks
Old 06-24-01, 06:04 PM Thread Starter   #7
swanie
Hi again.
I just cant understand what the ambient temp has got to do with watercooling as it is the water that is cooling the block and not a fan.
I understand the whole concept of checking the temps when it comes to air cooled units, but I am sure it must be different for water cooling.
Old 06-24-01, 07:42 PM   #8
Thelemac
Thelemac's Avatar
10 Year Badge
There isn't any difference, cause the ambient temp is the goal...water isn't going to go below that without somewhat extreme measures. Since that's the goal, you check the temp of the processor and subtract the ambient temp to get how much the water is able to cool the processor (actually the water is cooling the waterblock, as it doesn't actually come into contact with the cpu, but that's really just nitpicking on my part) and when you divide that by the watts your cpu is putting out you get how well the waterblock is able to remove the heat (so the units of c/w are degree C per watt given off)...
I hope this makes it clear to you.
__________________
42 | Sig Assassin
*click*
Old 06-24-01, 08:19 PM   #9
rugby
King of Cats Senior
rugby's Avatar
Quote:
swanie (Jun 24, 2001 06:04 p.m.):
Hi again.
Hi there, ambient temps have EVERYTHING to do with watercooling because you are still using a fan to cool if you have a radiator. My water setup consists of a waterblock, radiator, 120mm fan, and in-line pump/reservoir. THe water leaves the reservoir, goes to the waterblock on the cpu, and then goes to the radiator which is copper tubing with little fins on it. There is a 120mm fan attached to the radiator, drawing air through the radiator to cool the water. If the air in the room is really cold, the water is cooled more. THAT's the importance of ambient air temps. Here's a pic that shows a fan and radiator:
rugby is offline   QUOTE Thanks
Old 06-25-01, 07:44 AM   #10
AMDGuy
AMDGuy's Avatar
Quote:
rugby (Jun 24, 2001 08:19 p.m.):
Hi again.
Be careful here. Don't confuse "ambient" and "room" temps. Ambient is measured 1" from the processor. Room temp would be measured at the intake to the radiator. These will likely be different temps. For instance my "ambient" is around 32 C. Room temp is around 26 C. You have to consider actual ambient temp for the C/W equation because thermal properties dictate that at higher temps heat transfer is less efficient.
__________________
-AMDGuy
Gigabyte P55 UD3R
Old 06-25-01, 03:59 PM Thread Starter   #11
swanie
Hi
Wow... what a response :-)
Thx chaps. Now that I have the answers I can move on to greater things
2 thumbs up to overclockers.com
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
