Everytime I try and install my soundblaster live 5.1 into my computer it ends up by screwing over the whole OS. First I get windows up and runnung fine with no sound card installed, everything works fine. I have a soyo dragon plus mother board so I can use the onboard sound with no problems. When I want to switch over to the soundblaster, I first disable the onboard sound in the bios install the SBL and start it up. The SBL makes my computer lock right after xp detects it and installs the drivers. So ill reboot and in the device manager it has little yellow exclamation points bu the video card. It says some device on my radeon card isnt installed or some bs like that. So I click reinstall drivers which xp does. Now everything is fine, no exclamation pionts. But windows still locks up. I got ****ed and decided to take the SBL out of my computer. When irestarted windows wthout the SBL it said
missing or corrupt c:\windows\system32\config\system file
Windows it totally screwed over now and I cant fix it, so I reformatted and reinstalled everything. (i have done this twice already. Im afraid to put the card back in again.
Could I have a broken sound card here, or maybe bad ram? Or is windows just having some kind of conflict between these devices. I did have both of these devices(SBL and radeon VIVO) installed for some time and this problem just happened a few weeks ago. Could xp not like my video card drivers when the SBL is installed. HELP !!!!
Hardware
Soyo dragon plus
xp2100
micron pc2100
ati radeon vivo
scsi 15k
Software
Windows xp pro
Hardware
Soyo dragon plus
xp2100
micron pc2100
ati radeon vivo
scsi 15k
Software
Windows xp pro
