Notices
Overclockers Forums > Hardware > Motherboards > AMD Motherboards
AMD Motherboards
Forum Jump
Non-ECC/Unbuffered... what does that mean?
Thread Tools
Old 11-21-02, 11:30 AM Thread Starter   #1
Amino
Amino's Avatar
Ok, I've got an 8K3A+ and was wondering about something.
At nutrend.com, I see 2 types of PC2700 memory... one says "Unbuffered Requires DDR supported Motherboard," and also is Non-ECC while the other doesn't. The Non-ECC one is also about 15 bucks more expensive.
So I was wondering what the difference between the two were, and if my mobo supported the Non-ECC stuff, because I'm confident that my board's a DDR one. I mean, I'm pretty sure I have DDR ram in there now!
Here's the link to the web site: http://www.nutrend.com/app/search.as...nufactory=1666
Amino is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 11-21-02, 01:13 PM   #2
Mooky
ECC stands for Error Correction Code. As you can guess, it's a means of verifying the integrity of your memory. The method used is a little bit more complex than simple parity checking and can detect double bit errors. Most people don't use it. It's pretty much used in servers. Same with registered memory. Furthermore, it slows performance.
Mooky is offline   QUOTE Thanks
AMD Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
