I personally don't use the washers and I don't have any grounding problems or anything of the sort so I am sure if you are using poly screws then you'll be fine w/o.
yah the washers standardly help in 2 things.
1 i guess people are worried of conductivity, i know myself im not however some are.
2 and i beleive the real purpose of them is for you to keep from chewing the hell outta your mother board...
i never used plastic washers (i couldn't be arsed to filddle with the lil buggers). With out them just make sure you don't crush your mobo by tightening the screws too much. ive never seen a mobo crack due to strain from the screws but i guess you will be alright as the waterblock doesn't weigh that much.
