Notices
Overclockers Forums > Hardware > Motherboards > AMD Motherboards
AMD Motherboards
Forum Jump
CPU to PCI Divider on KT400 Dragon Plat Ed
Thread Tools
Old 04-06-03, 01:12 AM Thread Starter   #1
travioli
travioli's Avatar
Question CPU to PCI Divider on KT400 Dragon Plat Ed
First time poster, long time reader. I just started adjusting the overclocking features of my Soyo KT400 Dragon Plat Ed a couple of weeks ago after I got my new heatsink (SLK-900U). I easy got the FSB to 145 with out changing any other settings but after a few days of that I wanted more. I have a locked (I plan to try an unlock it over te summer) Palomino 2000+ and I haven't found great things about their overclocking ablity. I was able to reach 150 on the FSB after much trial and error and adjusting the CPU voltage to 1.8, the DDR voltage to 2.7 and the AGP voltage to 1.6. The manual suggested changing the divider to 1/5 but i can't get it to boot with that setting. I was wondering if maybe my ram was holding me back or if other people have had problems with changing the divider. I was also wondering where i would go from here to try and reach better speeds. Thanks.
travioli is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 04-06-03, 11:08 AM   #2
mariner1911
You might try raising your voltages one at a time. While my cpu wanted more voltage, my RAM would only function properly at the default voltage.
mariner1911 is offline   QUOTE Thanks
Old 04-10-03, 06:59 PM   #3
giomatta
Welcome to the forum.
Done the same myself, with a kt400 dragon ultra and a palomino 2000+.
Well, I think the problem is the 2000+, first because it’s not a champion of oc, and then – mainly – because is locked. I have been forced to unlock mine (losing a part of my sight in doing it …), after every other attempt to raise the fsb went failed. Now my cpu goes@10x176, 1.85 volts, with agp at 1.5 volts and my pc2700 ram at 1.6 (only for being sure; but goes stable also at 1.5). The whole thing is rather stable; only sometimes and only with certain games the pc locks. But, I repeat, the problem is the palomino; and in my case the timings of the ram, that are almost all at their best, and the heatsink, not a monster of cooling. But maybe in your case also the ram has reached its limit (I have a 166 fsb, not a 133 like you; so I cannot tell you where is your upper limit).
So now I can set the divider to 1/5, and my bandwidth is a little (…) better than before. If you want to do the same, I’m afraid you’ll be obliged to unlock your cpu, to go beyond the 151 fsb limit (as seen in the manual; but I think the limit is rather 151, or 152).
Don’t know, I’m thinking to change the palomino for a tbred, with superior oc capabilities and a minor voltage.
hi.
giomatta is offline   QUOTE Thanks
Old 04-12-03, 02:20 PM   #4
giomatta
beg your pardon: ram voltage at 2.6 volts, of course, not 1.6.
have a niiice day.
Old 04-12-03, 02:40 PM   #5
Paradoxmaker
Paradoxmaker's Avatar
Right now ny Kt400 Dragon Ultra is running along nicley with my 2100B chip at 161*13 with the /4 divider.
So my busses are 80pci/40agp (or do I have that backwards?)
Paradoxmaker is offline   QUOTE Thanks
Old 04-12-03, 06:11 PM   #6
JBRONCFAN
Dude, if you're into overclocking at all, you need to purchase an AMDXP2100+ Thourouhbred, revision B which is shipped unlocked. Newegg is actually having a sale on this chip for $85 (I bought one for $95 a month ago). Check out my specs below and here's the link:
http://www.newegg.com/app/ViewProduc...codevalue=4159
My overclocked AMDXP runs just as fast as their 2700 except their 2700 costs $262......ya feelin' me!?!?!?!? $262 - $85 = $177 savings to you!
__________________
Sabertooth 990FX AMD-FX 8350 Running at 4ghz
(2) 8gig DDR3 1600
128gig OCZ Vector 60gig Intel SSD 3 Slave 7200 Drives
Gigabyte 7950 w/3gigs RAM
Antec 850
Samsung 26" HD Monitor/ 42" HDTV
JBRONCFAN is offline   QUOTE Thanks
AMD Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
