Notices
Overclockers Forums > Hardware > Display and Sound Technology > Sound Systems & Audio Devices
Sound Systems & Audio Devices Including sound cards, speakers and other audio devices.
Forum Jump
My Soundstorm Review
Thread Tools
Old 06-22-03, 06:41 AM   #21
james.miller
james.miller's Avatar
Quote:
Originally posted by bigemike
hey grunjee, go buy a $20 optical cable and hook up your z-680's with that to you nf7-s and try it. I couln't say that my audigy was better once I hooked up the z-680's optically to my nf7-s. All I can say is that it is alot better than analog or coaxial digital. let me know what you think. I am interested becouse I am comparing and audigy gamer to the nf7-s and I think the nf7-s rules, and the optical made it that much better. Not hooking them up optically is stepping back a few years in sound quality.
there is no way that optical can be better than co-ax unless a) you used a cheap co-ax cable, or b) your speakers perform better with optical for some reason.
to get optical out, co-ax has to be converted from electrical >> optical and at the other end of the cable, Optical >> electrical. Asuming everything is in working order, optical can only sound worse, since you have to deal with 2 extra conversion processes. (the difference may be so small that you can't actually hear it - but its there.
__________________
The HTPC
E2160 @ 2.7ghz | Thermaltake The Orb cooler | Asus p5w-dh | 4Gb DDR-II pc6400| 1.00Tb of WD AAKS storage | Asus Xonar D2| 360 HD-DVD drive
Pioneer bd204 bluray sata drive | Corsair HX620w PSU | BFG GeForce 8800GTX | Silverstone SST-LC17b
| 22" dell e228wfp | 40" 1080p SONY 40w2000
ONKYO TX-SR805 | bi-amped mission m71i fronts | eltax center & bipolar rears
2x 12" custom built subwoofers powered by a denon pma-100m | PS3 with linux and a 250gb 3.5" internal drive | Nintendo wii
james.miller is offline   QUOTE Thanks
Old 06-23-03, 11:58 PM   #22
bigemike
bigemike's Avatar
when I am comparing the three seperate inputs (analog 6ch) on my audigy with the analog outputs on my nf7-s the soundstorm sounds as good or better than the audigy. But when I hooked up the single fibre optic cable for digital my sound improved quite alot from anything I had before. I never could get my audigy to work with the spdif output, is there a special cable needed or what. I tried a mono headphone jack to rca adapter from radio shack and I could only here like 4 channels or something. Anyone have an idea on how to hook this up. Let me know if anyone has the laydown on that.
secondly if the rca style input is cleaner than the optical I would like to hear some more about that as well. I figured the 0 resistance of the optical cable would have to be the best.
Plus that little l\red light amazes people when you tell them it makes all that music pumping out of my z-680's
I did get a little hiss through my speakers when I went optical that I didn't have in analog 6ch input. Let me know if anyone has expierianced it.
__________________
pc#1 amd3000 socket 939 dfi sli nforce 4, 2 gigs pc3200, 6800 , dvd-r enermax 550w supply, z-680's
pc#2 amd 3200 210x10.5 giel pc3200 2x 512, 6800 52xburner, dvd
pc#3 dell 9400 dual core laptop 2gig, 7900 gs dvdrw 17" tru life
pc#4 Compaq 900 mhz duron laptop with ubuntu
bigemike is offline   QUOTE Thanks
Old 06-28-03, 01:38 AM   #23
Audioaficionado
Super Moderator
Audioaficionado's Avatar
10 Year Badge
I mainly use my Soundstorm for playing high bit mp3s on my main audio system using the analog stereo outputs. Sounds better than my SB Live 5.1 but it's not audiophile quality by a long shot. Someday I'll try the digital feed.
__________________
.....................................My HeatwareMyFAH Stats
.......................Folding is a marathon, not a sprint © audioaficionado
Asus Commando, 8GB GSkill 5-5-5-15-2t PC6400, Q6600 @3.0GHz >SMP2+GPU3 FAH 24/7
Gigabyte DS3, 3GB GSkill 5-5-5-15-2t PC6400, E6400 @3.0GHz
Asus P5Q PRO Turbo, 4GB GSkill 5-5-5-15-2t PC6400, E6600 @3.0GHz
Iwill DH800, 2GB OCZ4002048PFDC-K 2.5-3-3-8-1t, Dual 2.4 M0 Xeons 1.5v/880/3300
Help improve overclockers.com! Get involved!
You have over 101 posts and Can't see the classifieds???Click This Link
Anyone we catch cookie stuffing at this site will be banned on the spot!!
Audioaficionado is offline Folding Profile Heatware Profile   QUOTE Thanks
Old 06-29-03, 12:31 PM   #24
weponhead
weponhead's Avatar
In reply to earlier , "heat on a audigy causes crackling in some games" Really? i never knew that .. That explains the kinda fuzzieness i get when playing AA for a long time ! lol MORE COOLING!
weponhead is offline   QUOTE Thanks
Old 06-29-03, 12:42 PM   #25
pauldriver
pauldriver's Avatar
I don't think that the Audigy does Dolby Digital AC3 Encoding, yeah according to this link http://soundblaster.com/products/audigy/specs.asp the Audigy does Digital PCM output only.
[edit] The smoking gun http://dmzweb4.europe.creative.com/u...ve_ac3dd12.htm I linked this from a Audigy FAQ, so apparently neither the Live! or the Audigy do AC3 encoding.
A lot of Dolby Digital products won't handle a raw PCM input. The Creative speakers that are designed for digital PCM input won't handle a Dolby Digital AC3 input at all.
Paul.
pauldriver is offline   QUOTE Thanks
Old 06-29-03, 12:52 PM   #26
D $hady
D $hady's Avatar
Quote:
I got a suggestion in another thread: http://forum.oc-forums.com/vb/showth...adid=205651... look at the last post. Doing this (changing settings in device manager; still no heatsink) solved my crackling problems when playing BF1942. Hopefully it will help some others out too!
D $hady is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
