- Aug 13, 2003
- SW and SE Michigan
therudyq3 said:what about IS7 ??
micamica1217 said:
maybe soon.
I do know that they(abit) want to see if it realy works on the IC7 first.
maybe by today, if it doesn't hurt other things, they will reliese it for the IC7.
about one week from now, if all goes well, you'll have it for the IS7.
mica
micamica1217 said:
Xymurgy said:From Abit Marketing:
>>The official BIOS 17 for IC7 will be released late next week and IS7 16 will be released early next week. The major fixes are the 255Mhz FSB barrier issue and the Maxtor hard drive bug.
Thank you all for your patience waiting. <<
http://forum.abit-usa.com/showthread.php?s=&threadid=20130&perpage=15&pagenumber=3
therudyq3 said:
Mica I thought you have a 2.4B cpu...unless you have a C sitting somewhere...
also, will you put your 2.4B in and see if you can gain any additional fsb from the cpu or from the memory ??
THX
P.S. I guess I have to wait another week for an IS7 BIOS huh..
micamica1217 said:
I'm still running a 2.4b, and will not get a 2.4c (or other C chips).
I'm hoping for two things though, first that the new prescott works (and I still see no reason it should not) and 5:4/1:1 ratio works over 255fsb....it now does, yet still a little buggy.
my next upgrade will be a 3.2ghz prescott and pc4000/4200....
I hope to keep this mobo.
mica
therudyq3 said:
uummm early rumors is that Prescott will need a new socket. But it would be great if it works on the IC7 or IS7.
